Im trying to wire 4 3v LEDs in series, I tested one light to make sure it worked with a standard 9v battery. It lit for a second then dimmed out. Did I burn out the light, or is the battery not right for it? If anyone could help with what size battery I should use that would be great.
Thanks
  • \$\begingroup\$ electronics.stackexchange.com/questions/36433/… (yes, you've probably burned it out) \$\endgroup\$
    – pjc50
    Apr 2 '13 at 21:47
  • \$\begingroup\$ You hooked up a 3V something to 9V. What do you think? \$\endgroup\$
    – Kaz
    Apr 2 '13 at 22:20
  • \$\begingroup\$ @angelatlarge Current limiting diodes? You mean resistors perhaps? \$\endgroup\$ Apr 3 '13 at 10:16
  • \$\begingroup\$ @Anindo Ghosh: Oh, man, I did that again! Yes, that's what I meant. Grrrr... \$\endgroup\$ Apr 3 '13 at 15:20
10
To start, yes, that LED is definitely burned out. If an LED is listed for a specific voltage, that means it will typically "drop" that much voltage at some listed current - typically 20 mA. So if 20 mA are passed through the LED, it will "drop" 3 V. The current to voltage ratio is usually directly related: as one goes up or down, the other goes up or down.
Ohm's law states that:
$$Voltage = Current \times Resistance$$
For a 9 V battery with virtually no resistance, the LED current would have been very high. To use the LEDs without a resistor, you connect all 3 in parallel across 3 V (a 3.3 V coin cell battery, or 2xAA batteries in series). Any higher voltage will burn the LEDs out. Any lower and they probably won't light up. Similarily, you could probably get away with connecting 3 LEDs in series across a 9V battery, but I wouldn't recommend it. Also, if you burn out an LED, don't breathe in the fumes from it. LEDs have some pretty nasty chemicals inside of them that aren't meant for inhalation.
Every type of LED is different. White LEDs are typically around 3 V while red LEDs are typically around 2 V. Also, different kinds have vastly different current ratings, from 20 mA to 2 A. Common 3 mm or 5 mm LEDs are more in the 40 mA range. Unless you are just messing around and learning, you should always use a series resistor with an LED to control the current through it.
In general, the more current through an LED, the higher its voltage drop will be, and the brighter the LED will shine. However, each LED has a maximum voltage and current rating. An LED has almost no internal resistance, so connecting it directly to a battery will put the full battery voltage through the LED. It will shine very brightly for a second, then overheat from the high current draw and burn out. Had you placed a resistor greater than 200 ohms in series with the LED it would have been fine: \$\dfrac{9\,\mathrm{V} - V_{LED}}{200\Omega}\$ = LED Current... \$\dfrac{6\,\mathrm{V}}{200\Omega} = 30\,\mathrm{mA}\$.
As far as arranging the LEDs, you can do it in many ways. To do it in series: Series LEDs
When things are in series, then share a current but have individual voltages. On the left are 3 LEDs in series with a series resistor. Since they are in series, they will "share" a current, meaning the same number of amps will pass through everything. However, each component will have its own voltage drop. Similar rated LEDs will not typically have identical voltages, so while LED1 may drop 3 V, LED2 may drop 3.2 V and LED3 may drop 2.8 V. In this case, the resistor (R1) will "limit" the current through the LEDs by dropping whatever voltage is left over. The battery voltage is given by the following equation:
$$V_{BAT} = V_{LED1} + V_{LED2} + V_{LED3} + V_{R1}$$
If (on average) each LED is dropping 3 V, then there is \$V_{BAT} - 3 \times 3\,\mathrm{V}\$ left over. With a 12 V battery, \$V_{R1} = 3\,\mathrm{V}\$. The current through everything would be \$V_{R1}/R_1 = I_{LED}\$. If \$R_1 = 1000\Omega\$, then \$I_{LED} = 3\,\mathrm{V}/1000\Omega = 3\,\mathrm{mA}\$. A lower resistance will equal a higher current, but since the LED voltage drop is dependent upon the LED current, it is not always that simple to pick out the proper series resistance.
On the right are 2 parallel banks of 3 series LEDs, each with its own series resistor. All of the calculation are the same in this circuit as they were in the first. The only additional thing to note is that the total voltage across the left string will be equal to the total voltage across the right string because the strings are in parallel. However, the current through each string could be different, depending on the chosen series resistance in each string. The total current flowing from the battery is equal to the two string currents added together.
To do it in parallel: Parallel LEDs
When things are in parallel, they share a voltage but have individual currents. The circuit to the left is common, but not very smart. The 3 LEDs are in parallel and share a single series resistor. In this manner, the LEDs are "forced" to have identical voltage drops. A lower source voltage is necessary here. The total current is still set by the single resistor, similar to the above circuits. This total current is equal to the sum of the three LED currents. For example, with a 6 V battery, 3 V LED (on average), and a 1000 ohm resistor, the LED current would be \$\dfrac{6\,\mathrm{V} - 3\,\mathrm{V}}{1000\Omega} = 1\,\mathrm{mA}\$. The circuit is really only a bad idea if you are operating the LEDs near their max current. Since the LEDs won't draw identical currents at the same voltage (each one is a little bit different) then one may burn out, causing the current through the other two to immediately go up since they share the current limiting resistor. This will likely cause the other LEDs to burn out as well.
On the right is the best way to do this, with each LED having its own series resistor. In this way, the current through each LED can be controlled, and each LED will continue working if any of the other ones burn out. \$I_{LED} = V_R / R\$. Each LED and resistor combination will have a total voltage drop equal to each other LED and resistor combination, but each LED can have a different current, depending upon the size of the resistor.
In Summation:
If you have a high voltage source, say 12 V, it is common to use parallel strings of series LEDs, such as the right circuit in the first image. Using a single LED will mean a much higher voltage drop across the resistor. This works, it is just a lot of wasted power. If you have a low voltage source, say 5 V, it is common to use parallel strings of LED and resistor combinations, such as the right circuit in the second image. If the voltage source is nearly identical to the rated LED voltage, say 2 V - 3 V, then you can omit the series resistor and connect the LEDs in parallel directly across the battery.
A switch can be placed between either battery terminal and the LEDs.
  • \$\begingroup\$ "In general, the more current through an LED, the higher its voltage drop will be" - are you sure about that? I thought the Vdrop was relatively constant, regardless of I. \$\endgroup\$ Apr 3 '13 at 6:42
  • \$\begingroup\$ Relatively speaking, you're right. The fluctuation size is based on the kind of LED. I've seen a change in over a Volt, depending upon the current I put through it. It isn't a big deal to me unless I'm putting a few in series, which is normal when I have a 12V (or greater) source. Take a look at this datasheet for a common 3mm LED. On page 5, there is a curve for forward voltage vs forward current. promelec.ru/pdf/204-15UTC-S400-X9.pdf \$\endgroup\$ Apr 3 '13 at 7:52
That one is dead. LEDs need a resistor in series to protect from excessively high currents: since LEDs present virtually no resistance to current, the allow very high currents across them, which is not good for their health. Some batteries cannot source enough current to burn out some LEDs (for instance those "torch" types are OK with 2xAAA batteries), though the details depend both on the battery and the LED.
Also, when you say a 3V LED you probably mean a LED with a 3V forward voltage drop. This is not the most important characteristic: what you really need to know is how much current the LED can take. For most small LEDs it is about 20mA-25mA.
So to know what kind of battery you need you need to know:
  • How long you need the LED to be lit
  • What is the current draw you are shooting for (around 20mA/LED is the usual, but you'd need to consult your datasheet to see the maximum, and decide whether you want to have the maximum current drawn)
Then you can calculate the battery size. For most LEDs, at least a 3V battery set (such as 2xAA) is sufficient to drive the LEDs, but again, you may need current-limiting resistors depending on the LEDs and the battery.
  • \$\begingroup\$ Ok, yeah I am really new to this, I'm just trying to wire some together for a home project. I attached 2xAA batteries to one LED and it lit. If I were to use three LEDs, would/should I hook them up in parallel? Basically I just want to have all three connected to a switch. What would be the easiest way to accomplish this? \$\endgroup\$
    – John
    Apr 3 '13 at 3:23
