Is it possible to calculate what input power (watts) is needed to run a given PWM at a certain line frequency (hertz)?
I have all the motor parameters, I know:
- P-nom, nominal power, kW
- U-nom, nominal voltage, V
- f-nom, nominal (line) frequency, Hz
- N-nom, nominal speed, RPM
- I-nom, nominal current, A
- cosPhi, power factor
- pole count
I need to make a function that takes in a line frequency and outputs power used by the motor at that frequency.
EDIT Will give some more information on what i'm actually trying to achieve.
I work at a company that makes inverters that has true sinusoidal line frequencies. PWM chops up the volt into pulses with different widths that makes it so the flow resembles a sinus wave. When doing this energy is lost into uninteresting forms of energy for the system (sound, heat, etc) that we can disregard. Especially at lower frequencies. At 50Hz our inverter is not that much more energy saving than a PWM, our big strength is that at lower hertz (like 10-30Hz) there is a big waste in PWM motors.
My boss asked me to make a program that can show 2 line graphs, one for our inverter and one for a standard/average PWM inverter. Where the Y-axis of the graph is power consumed (watts) and the X-axis is the line frequency from the inverter to the motor (hertz).
