I am designing a simple encryption circuit on Xilinx Virtex-5 FPGA. I have given the timing constraint in the UCF as below:
NET "clk" TNM_NET = clk;
TIMESPEC TS_clk = PERIOD "clk" 25 ns HIGH 50%;
My design does not have any errors in static timing analysis report after place and route. Part of the report is shown below:
Timing errors: 0  Score: 0
Constraints cover 191219 paths, 0 nets, and 38438 connections
Design statistics:
   Minimum period:   9.954ns{1}   (Maximum frequency: 100.462MHz)
However, when I run a post place and route timing simulation in modelsim. It gives me this error and the design does not generate the proper result in the simulation.
# ** Error: /home/rex/opt/Xilinx/10.1/ISE/verilog/mti_se/simprims_ver/simprims_ver_source.v(121020): $hold( posedge CLK:650974 ps, negedge I &&& (in_clk_enable1 != 0):651125 ps, 153 ps );
#    Time: 651125 ps  Iteration: 0  Instance: /tb/aes_wrapper_0/\aes_fwd_0/aes_fwd_core_inst/CIPHER_RND_1_ARK_ROW_1_4_ARK_COL_1_3_xor_itm_1_sg1
#    Time: 651125 ps  Iteration: 0  Instance: /tb/aes_wrapper_0/\aes_fwd_0/aes_fwd_core_inst/CIPHER_RND_1_ARK_ROW_1_4_ARK_COL_1_2_xor_itm_1_sg3_0
#    Time: 651125 ps  Iteration: 0  Instance: /tb/aes_wrapper_0/\aes_fwd_0/aes_fwd_core_inst/CIPHER_RND_1_ARK_ROW_1_4_ARK_COL_1_3_xor_itm_1_sg3_0
# ** Error: /home/rex/opt/Xilinx/10.1/ISE/verilog/mti_se/simprims_ver/simprims_ver_source.v(121019): $hold( posedge CLK:650974 ps, posedge I &&& (in_clk_enable1 != 0):651125 ps, 153 ps );
#    Time: 651125 ps  Iteration: 0  Instance: /tb/aes_wrapper_0/\aes_fwd_0/aes_fwd_core_inst/CIPHER_RND_1_ARK_ROW_1_4_ARK_COL_1_2_xor_itm_1_sg3_2
#    Time: 651125 ps  Iteration: 0  Instance: /tb/aes_wrapper_0/\aes_fwd_0/aes_fwd_core_inst/CIPHER_RND_1_ARK_ROW_1_4_ARK_COL_1_3_xor_itm_3
I only know this is a hold time violation. How do I interpret this error information more precisely? How to solve this problem?
Updates: I tracked the signals that cause the hold time violation. The input pad is connected to some combinational logic before it goes to the DFF which has hold time violation. I assume adding OFFSET IN constraint will solve this problem. How do I determine the right value (??ns) in the OFFSET IN constraint?
OFFSET = IN ??ns BEFORE "clk";
    \$\begingroup\$ I'd start by upgrading your tools. 10.1 is a good number of versions behind the current 14.4. Since the hold violation was not reported during synthesis, but modelsim picks it up, there might be an issue with the tools that has been fixed since 10.1 \$\endgroup\$
    – stanri
    Apr 3, 2013 at 4:26
  • \$\begingroup\$ Do you recognize the register in the error message? Could you put up some code showing any relevant connectivity? Reading this app note, it says that "At a minimum, every design should have PERIOD, OFFSET IN, and OFFSET OUT constraints.". I don't know if this applies to you, but might want to read this: xilinx.com/support/documentation/white_papers/wp237.pdf \$\endgroup\$
    – Tim
    Apr 3, 2013 at 4:28
  • \$\begingroup\$ yeah but ISE 10.1 was one of their better efforts. For Virtex 5 it's fine. @Rex : trace both source and destination points on a failing signal - it is likely that one or the other is not a regular FF (possibly BRAM, mult or I/O pin). Often you need to add timing constraints to cover I/O signals and special function blocks (BRAM used to need its own constraints) \$\endgroup\$
    – user16324
    Apr 3, 2013 at 8:58
  • \$\begingroup\$ Trace where the inputs to this signal come from - if any are external and asynchronous, you will see violations. \$\endgroup\$ Apr 3, 2013 at 15:56
  • \$\begingroup\$ @StaceyAnne, I agree with Brian, 10.1 is a major software launch along with Virtex-5 series. The lastest version I tried before is 13.1. I do not find anything particularly more useful. \$\endgroup\$
    – drdot
    Apr 3, 2013 at 20:41
If you don't get a violating in timing analysis, but do in simulation, your timing analysis is likely incomplete. Revisit clock crossing and TIG (ignore) in particular. See Xilinx answer 38348 for more details on TIG.
  • \$\begingroup\$ Thank you Brian, I cannot find the word "crossing" or "TIG" in the timing report. Could you elaborate? BTW: What does TIG mean? \$\endgroup\$
    – drdot
    Apr 3, 2013 at 21:21
    \$\begingroup\$ @rex, TIG = timing ignore, it's the keyword for ignoring a particular path in the constraints file. \$\endgroup\$
    – stanri
    Apr 4, 2013 at 1:11
