Can somebody help to check the part number for this IC from its marking? This IC is used in an ESD monitoring device.
I tried to google "IC 6017808", but no results.
  • \$\begingroup\$ i just found this in Aliexpress, cannot provide better picture, for the title already change \$\endgroup\$ Nov 12, 2022 at 5:14
  • \$\begingroup\$ the logo looks like ST Microelectronics \$\endgroup\$
    – jsotola
    Nov 12, 2022 at 5:17
  • \$\begingroup\$ Yes correct, can you help me to check this one ? \$\endgroup\$ Nov 12, 2022 at 5:17
  • \$\begingroup\$ why do you want this info? \$\endgroup\$
    – jsotola
    Nov 12, 2022 at 5:50
That looks like an St LM324. You’ll have to chase out the circuit a bit to be sure. datasheret pinout
  • \$\begingroup\$ Yes, you're correct \$\endgroup\$ Nov 20, 2022 at 9:56
  • \$\begingroup\$ @RizkisWalker thanks for following up. Can you mark this answer as correct then? \$\endgroup\$
    – Bryan
    Nov 20, 2022 at 17:00
