-1
I want to connect XBee to PC , does xbee send serial data or need UART to do that ?
closed as unclear what you're asking by PeterJ, Null, Daniel Grillo, Fizz, Dave Tweed Oct 20 '15 at 13:38
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ It depends on what you mean by XBee. XBee is a communication protocol specification, like Ethernet. Your XBee implementation (module or chip) may have a UART or not. \$\endgroup\$ – angelatlarge Apr 3 '13 at 16:48
    \$\begingroup\$ I think most XBee modules use some sort of serial interface, but yes, OP needs to specify which specific device is intended for the application. \$\endgroup\$ – Adam Lawrence Apr 3 '13 at 17:28
Here's what you're probably looking for.
https://www.sparkfun.com/products/8687
Provided you have another xbee somewhere communicating to the one plugged into your PC, download the drivers for that board, open up a serial terminal, set the baud rate to 9600 (xbee series 1 default) and away you go!
