Two separate solar charger/inverter systems will be installed on a camper, each with a separate ground connected at two separate points on the chassis. Is this logical? The likelihood of them discharging at exactly the same time seems unlikely, and even if they did, there is probably enough material to handle it. I just want to hear perspectives on if this is reasonable.
I fear my question is kind of basic compared to many of these posts, but I am having trouble finding an answer that makes sense. Also, I promise to hire a certified professional to double check my plans but just want to make sure there isn't a glaring hole in my logic while thinking about the set up.
