I want to add an NVHL080N120SC1_3P MOSFET to this circuit with an encrypted ONSEMI_SiC_MOSFET.txt file. How can I do this?
    \$\begingroup\$ On semi have a document the explicitly tells you how to use encrypted files for LTSpice. \$\endgroup\$
    Nov 17, 2022 at 18:32
    \$\begingroup\$ Have a look at that AN in which all the steps are detailed. \$\endgroup\$ Nov 17, 2022 at 18:33
This section in AND9873 - How to use Physical and Scalable Models with SIMetrix, OrCAD and LTSpice should provide you with what you need: -
You should try figuring it out for micro-cap for a laugh. It wasn't very obvious but I did get there.
  • \$\begingroup\$ care to share How DID You import encrypted model to micro-cap ? I haven't succeeded. \$\endgroup\$
    – crypton
    Aug 1, 2023 at 10:41
  • \$\begingroup\$ Not really an answerable question in comments. Try raising a new formal question. \$\endgroup\$
    Aug 1, 2023 at 12:20
  • \$\begingroup\$ Sure thing, did this here: electronics.stackexchange.com/q/676116/123589 \$\endgroup\$
    – crypton
    Aug 1, 2023 at 14:52
