I have found disused phone wiring in the walls of a house in Lithuania. The cable was probably installed around 2014 and has the following wire colors:
- white
- yellow
- orange
- green
- gray
- red
White/yellow are connected to the phone jack in at least one place (white on pin 3 of an RJ12 jack, yellow on pin 4); orange/green have been used in one place for a bridge between two RJ12 jacks (orange on 3, green on 4).
I have been unable to match this up with a known standard. Any hints?
If it helps, Lithuania nowadays seems to use mostly RJ11/RJ12 jacks for analog phone wiring. The Polish WT-4 standard (known in Russian as ШТР-IV) is also found, mainly in older installations, but jacks and plugs are still sold. The house in question has RJ12 jacks throughout.
