I want to make an input for an ESP32 using a MOSFET for active low. Will this schematic work?
The source is from a 5 V digital pin. I use a DMG1012UW MOSFET.
  • \$\begingroup\$ What happens when the source pin is at 0 V? You need a pull-up resistor on the ESP32 pin to 3.3V, or activate the ESP32's pin's internal pull-up, if any. \$\endgroup\$
    – ocrdu
    Nov 20, 2022 at 11:00
  • \$\begingroup\$ Why don't you just use an inverter that is capable of handling 5 volt inputs? \$\endgroup\$
    Nov 20, 2022 at 12:29
  • \$\begingroup\$ @ChristopherMoore You're right, my brain misread R23 as 100k, not 100R. Deleted. \$\endgroup\$
    – TypeIA
    Nov 20, 2022 at 21:51
