I am unsure if I am framing the question correctly, but here's what I wanted to ask.
Let's say we want to implement a 64 kB memory. We would require a 16-bit address if we have byte-addressable memory.
One simple way would be to use a complete 64 kB block. Another approach would be to use four blocks of 16 kB each and the lower 14 bits of the 16-bit address and feed it into each memory block, and use the higher-order 2 bits to select which memory block this address points to. This implementation is fairly simple.
But what would happen if we had memory blocks of variable sizes? Say, we have four 4 kB memory blocks, two 8 kB memory blocks, and two 16 kB memory blocks.
How would we have an implementation, as I mentioned above? I don't see any practical benefits of this approach. I just wanted to ask if and how this can be implemented.
