The image below is about peak current mode control for a boost converter. Someone said that it's easier to make it stable by feedback a very small of output like 1/10 Vout (or R2 << R1).
However, he couldn't explain why. Can anyone explain?
EDIT:
From the comment, I realized that the statement is wrong. So I'd like to edit my question a bit. Let's assume that you can have any reference voltage you want, then how would the feedback resistors affect the stability? Or even you have a fixed voltage reference, you still have infinite choices for R1, R2 to get the same feedback ratio. How would the selection affect the stability?
