So I'm going through my textbook and I'm stuck on this problem:
  • Design a circuit that has two inputs, \$clk\$ and \$X\$, and produces one output \$O\$.
    • \$X\$ may change every clock cycle, and the change happens at the falling edge.
    • The circuit samples the input at every rising edge of the clock.
    • If the input is \$1\$, consider as read a \$1\$, else read a \$0\$. \$O\$ is \$1\$ (for one clock cycle, from positive edge to positive edge) if the last three bits read are \$110\$, with \$0\$ as the most recent bit.
Draw the state diagram. Close to an arc, show \$X=1\$ or \$X=0\$ to indicate whether the change of state happens when \$X=1\$ or when \$X=0\$.
How would one approach this problem?
First design the state machine without worrying about the clk. You have to remember something about what happened with the last 3 inputs, so at worst you are going to need 8(=2^3) states (but you can do substantially better than that.)
Once you have the state diagram, you need to choose an n-bit representation for each state. You will store this in an n bit register.
Then you write down the truth table for the transition function. There will be n+1 inputs (the n-bit state, and the 1 bit for X.) There will be n output bits (representing next state.)
Then you figure out how to implement a circuit that performs the truth table.
Finally, you need to implement the output function. This will be a circuit that is true when you are in the state where the last three bits are 110, and false otherwise.
In your final circuit you will have an n-bit clocked register, and a bunch of combinational logic.
