I am designing a power management unit (PMU), which takes the power from an alternator (alternator output: three phases, 30-85VAC, 35-130Hz, Max current: 20A).
I want to reduce the ripple using capacitors (Between the rectifier and a buck converter).
I would like to reduce the ripple to 500 mV. I found a formula for three phase rectifiers, but I am not sure if it is correct, because the value is too high.
The formula I found is:
C = I/6fVpp, where 'I' is the current, 'f' is the line frequency, and 'C' is the filter capacitance.
The most unfavorable situation is with the lowest frequency and maximum current:
C = 18A/(6·35Hz·0.5V) = 0.171 F = 171 mF.
Does anyone know if this formula is correct?
Thank you.
  • \$\begingroup\$ You should add a serial inductor just before the capacitors ... also to limit inrush current. \$\endgroup\$
    – Antonio51
    Commented Nov 21, 2022 at 11:47
    \$\begingroup\$ I don't understand, you have there LTspice, you've created the schematic, you have calculated the value, what's stopping you from pressing "run" and test for yourself? Here are a few tips: if you mean to have the source with a positive sequence then you need 0,-120,120 degrees for phases, you don't need 3 caps in parallel (just use one with equivalent value), it will help to use either a .model for diodes or select one from the database, and, finally, use a current source as the load with the flag load. \$\endgroup\$ Commented Nov 21, 2022 at 11:48
    \$\begingroup\$ Also, the ground on the sources side should not be tied directly to the sources -- use a 1Meg (or so) valued resistor to ground. If you'll plot the current you'll see why. Or use the same approach for the load side, but not with a common ground. \$\endgroup\$ Commented Nov 21, 2022 at 11:52
  • \$\begingroup\$ In other words, with two grounds where you have them, diodes are shorting out the supplies. \$\endgroup\$
    Commented Nov 21, 2022 at 11:56
  • \$\begingroup\$ Ok, thank you. But I put the image just to get the idea. \$\endgroup\$
    – Pablo
In any case, just be aware of inrush current, overvoltage's and some other things.
Here are 3 pictures which show these "problems".
