I got these errors. What should I do?
Circuit: * C:\Users\hp\Documents\LTspiceXVII\EKG Schaltung.asc
Error on line 10 : c3 n002 n009 470 pf
Unknown parameter "pf"
Error on line 13 : c1 n005 n004 3.3 mu
Unknown parameter "mu"
WARNING: Less than two connections to node NC_01. This node is used by V1.
WARNING: Less than two connections to node NC_02. This node is used by V2.
Direct Newton iteration for .op point succeeded.
Ignoring empty pin current: Ix(u3:1)
Ignoring empty pin current: Ix(u3:2)
Ignoring empty pin current: Ix(u4:1)
Ignoring empty pin current: Ix(u4:2)
Ignoring empty pin current: Ix(lm324:1)
Ignoring empty pin current: Ix(lm324:2)
Ignoring empty pin current: Ix(u1:1)
Ignoring empty pin current: Ix(u1:2)
Heightened Def Con from 1.01564e-006 to 1.01877e-006
Heightened Def Con from 1.02352e-006 to 1.02752e-006
Heightened Def Con from 1.02898e-006 to 1.03011e-006
Heightened Def Con from 1.03275e-006 to 1.03675e-006
Heightened Def Con from 1.04004e-006 to 1.04216e-006
Heightened Def Con from 1.04346e-006 to 1.04646e-006
Heightened Def Con from 1.04775e-006 to 1.05175e-006
Heightened Def Con from 1.05866e-006 to 1.06066e-006
Heightened Def Con from 1.06155e-006 to 1.06555e-006
Heightened Def Con from 1.0693e-006 to 1.0733e-006
Heightened Def Con from 1.08894e-006 to 1.09194e-006
Heightened Def Con from 1.11181e-006 to 1.11581e-006
Heightened Def Con from 1.18035e-006 to 1.18435e-006
Heightened Def Con from 1.36509e-006 to 1.36909e-006
Heightened Def Con from 1.52071e-006 to 1.52271e-006
Heightened Def Con from 2.0028e-006 to 2.0098e-006
Heightened Def Con from 2.28336e-006 to 2.28736e-006
Heightened Def Con from 3.52574e-006 to 3.52786e-006
Heightened Def Con from 3.55417e-006 to 3.55817e-006
Heightened Def Con from 4.01314e-006 to 4.01714e-006
Heightened Def Con from 4.64992e-006 to 4.65392e-006
Heightened Def Con from 8.35414e-006 to 8.35452e-006
Heightened Def Con from 2.24585e-005 to 2.24615e-005
Heightened Def Con from 2.72313e-005 to 2.72334e-005
Heightened Def Con from 2.72977e-005 to 2.73017e-005
Heightened Def Con from 2.7317e-005 to 2.7321e-005
Heightened Def Con from 2.7325e-005 to 2.7329e-005
Heightened Def Con from 2.73299e-005 to 2.73329e-005
Heightened Def Con from 2.73343e-005 to 2.73383e-005
Heightened Def Con from 2.73509e-005 to 2.73549e-005
Heightened Def Con from 2.74325e-005 to 2.74365e-005
Heightened Def Con from 2.74548e-005 to 2.74578e-005
Heightened Def Con from 2.74949e-005 to 2.74989e-005
Heightened Def Con from 2.75094e-005 to 2.75134e-005
Heightened Def Con from 2.7772e-005 to 2.77742e-005
Heightened Def Con from 2.77995e-005 to 2.78035e-005
Heightened Def Con from 2.78114e-005 to 2.78115e-005
Heightened Def Con from 2.78116e-005 to 2.78127e-005
Heightened Def Con from 2.78136e-005 to 2.78157e-005
Heightened Def Con from 2.78159e-005 to 2.78159e-005
Heightened Def Con from 2.7816e-005 to 2.7817e-005
Heightened Def Con from 2.7817e-005 to 2.78171e-005
Heightened Def Con from 2.78171e-005 to 2.78201e-005
Heightened Def Con from 2.78328e-005 to 2.78348e-005
Heightened Def Con from 2.7835e-005 to 2.7838e-005
Heightened Def Con from 2.7845e-005 to 2.7847e-005
Heightened Def Con from 2.78487e-005 to 2.78497e-005
Heightened Def Con from 2.78497e-005 to 2.785e-005
Heightened Def Con from 2.78502e-005 to 2.78522e-005
Heightened Def Con from 2.78524e-005 to 2.78526e-005
Heightened Def Con from 2.78526e-005 to 2.78556e-005
Heightened Def Con from 2.78559e-005 to 2.7856e-005
Heightened Def Con from 2.78561e-005 to 2.78591e-005
Heightened Def Con from 2.78606e-005 to 2.78609e-005
Heightened Def Con from 2.7861e-005 to 2.7863e-005
Heightened Def Con from 2.78704e-005 to 2.78706e-005
Heightened Def Con from 2.78709e-005 to 2.78729e-005
Heightened Def Con from 2.78885e-005 to 2.78905e-005
Heightened Def Con from 2.79844e-005 to 2.79874e-005
Heightened Def Con from 2.80593e-005 to 2.80613e-005
Heightened Def Con from 2.80726e-005 to 2.80727e-005
Heightened Def Con from 2.80727e-005 to 2.80747e-005
Heightened Def Con from 2.80758e-005 to 2.80759e-005
Heightened Def Con from 2.8076e-005 to 2.80761e-005
Heightened Def Con from 2.80761e-005 to 2.80765e-005
Heightened Def Con from 2.80774e-005 to 2.80774e-005
Heightened Def Con from 2.80775e-005 to 2.80786e-005
Heightened Def Con from 2.80787e-005 to 2.80807e-005
Heightened Def Con from 2.80807e-005 to 2.80808e-005
Heightened Def Con from 2.80809e-005 to 2.80811e-005
Heightened Def Con from 2.80826e-005 to 2.80828e-005
Heightened Def Con from 2.80828e-005 to 2.80849e-005
Heightened Def Con from 2.80864e-005 to 2.80874e-005
Heightened Def Con from 2.80875e-005 to 2.80885e-005
Heightened Def Con from 2.80885e-005 to 2.80885e-005
Heightened Def Con from 2.80886e-005 to 2.80886e-005
Heightened Def Con from 2.80886e-005 to 2.80896e-005
Heightened Def Con from 2.80896e-005 to 2.80916e-005
Heightened Def Con from 2.80949e-005 to 2.80969e-005
Heightened Def Con from 2.80974e-005 to 2.80975e-005
Heightened Def Con from 2.80975e-005 to 2.80987e-005
Heightened Def Con from 2.80998e-005 to 2.80999e-005
Heightened Def Con from 2.80999e-005 to 2.81019e-005
Heightened Def Con from 2.81034e-005 to 2.81034e-005
Heightened Def Con from 2.81034e-005 to 2.81054e-005
Heightened Def Con from 2.81059e-005 to 2.81089e-005
Heightened Def Con from 2.81094e-005 to 2.81116e-005
Heightened Def Con from 2.81119e-005 to 2.8112e-005
Heightened Def Con from 2.8112e-005 to 2.8114e-005
Heightened Def Con from 2.81154e-005 to 2.81154e-005
Heightened Def Con from 2.81154e-005 to 2.81166e-005
Heightened Def Con from 2.81172e-005 to 2.81173e-005
Heightened Def Con from 2.81173e-005 to 2.81173e-005
Heightened Def Con from 2.81173e-005 to 2.81176e-005
Heightened Def Con from 2.81176e-005 to 2.81186e-005
Heightened Def Con from 2.81186e-005 to 2.81206e-005
Heightened Def Con from 2.81209e-005 to 2.8121e-005
Heightened Def Con from 2.81213e-005 to 2.81233e-005
Heightened Def Con from 2.81237e-005 to 2.81239e-005
Heightened Def Con from 2.81239e-005 to 2.81259e-005
Heightened Def Con from 2.81307e-005 to 2.81318e-005
Heightened Def Con from 2.81318e-005 to 2.8133e-005
Heightened Def Con from 2.8137e-005 to 2.8137e-005
Heightened Def Con from 2.8137e-005 to 2.8139e-005
Heightened Def Con from 2.81411e-005 to 2.81433e-005
Heightened Def Con from 2.81434e-005 to 2.81435e-005
Heightened Def Con from 2.81435e-005 to 2.81445e-005
Heightened Def Con from 2.81445e-005 to 2.81448e-005
Heightened Def Con from 2.81448e-005 to 2.81458e-005
Heightened Def Con from 2.81458e-005 to 2.81469e-005
Heightened Def Con from 2.81469e-005 to 2.8147e-005
Heightened Def Con from 2.81471e-005 to 2.81472e-005
Heightened Def Con from 2.81472e-005 to 2.81483e-005
Heightened Def Con from 2.81483e-005 to 2.81486e-005
Heightened Def Con from 2.81488e-005 to 2.81489e-005
Heightened Def Con from 2.81489e-005 to 2.81501e-005
Heightened Def Con from 2.81518e-005 to 2.81538e-005
Heightened Def Con from 2.81541e-005 to 2.81543e-005
Heightened Def Con from 2.81544e-005 to 2.81544e-005
Heightened Def Con from 2.81544e-005 to 2.81556e-005
Heightened Def Con from 2.81556e-005 to 2.81556e-005
Heightened Def Con from 2.81556e-005 to 2.81576e-005
Heightened Def Con from 2.81576e-005 to 2.81596e-005
Heightened Def Con from 2.81597e-005 to 2.816e-005
Heightened Def Con from 2.816e-005 to 2.8162e-005
Heightened Def Con from 2.81625e-005 to 2.81646e-005
Heightened Def Con from 2.81676e-005 to 2.81698e-005
Heightened Def Con from 2.81703e-005 to 2.81705e-005
Heightened Def Con from 2.81705e-005 to 2.81708e-005
Heightened Def Con from 2.81709e-005 to 2.81739e-005
Heightened Def Con from 2.81803e-005 to 2.81805e-005
Heightened Def Con from 2.8181e-005 to 2.8183e-005
Heightened Def Con from 2.81832e-005 to 2.81852e-005
Heightened Def Con from 2.81861e-005 to 2.81873e-005
Heightened Def Con from 2.81953e-005 to 2.81973e-005
Heightened Def Con from 2.82009e-005 to 2.82039e-005
Heightened Def Con from 2.82048e-005 to 2.82068e-005
Heightened Def Con from 2.82195e-005 to 2.82197e-005
Heightened Def Con from 2.82199e-005 to 2.822e-005
Heightened Def Con from 2.822e-005 to 2.82204e-005
Heightened Def Con from 2.82208e-005 to 2.82228e-005
Heightened Def Con from 2.82228e-005 to 2.8223e-005
Heightened Def Con from 2.8223e-005 to 2.8226e-005
Heightened Def Con from 2.82322e-005 to 2.82325e-005
Heightened Def Con from 2.82333e-005 to 2.82335e-005
Heightened Def Con from 2.82343e-005 to 2.82354e-005
Heightened Def Con from 2.82356e-005 to 2.82396e-005
Heightened Def Con from 2.82413e-005 to 2.82423e-005
Heightened Def Con from 2.82423e-005 to 2.82444e-005
Heightened Def Con from 2.82452e-005 to 2.82462e-005
Heightened Def Con from 2.82465e-005 to 2.82467e-005
Heightened Def Con from 2.82467e-005 to 2.82468e-005
Heightened Def Con from 2.82468e-005 to 2.82468e-005
Heightened Def Con from 10.5896 to 10.5896
Heightened Def Con from 11.0569 to 11.0569
Heightened Def Con from 13.5256 to 13.5256
Date: Mon Nov 21 13:07:12 2022
Total elapsed time: 663.346 seconds.
tnom = 27
temp = 27
method = modified trap
totiter = 27705240
traniter = 27705208
tranpoints = 4930144
accept = 3398982
rejected = 1531378
matrix size = 95
fillins = 146
solver = Normal
Thread vector: 17.8/5.8[4] 4.8/3.4[4] 4.1/3.9[1] 0.8/3.2[1] 2592/500
Matrix Compiler1: 12.38 KB object code size 3.5/2.2/[1.1]
Matrix Compiler2: 8.99 KB object code size 1.6/1.9/[0.8]
