I need to solve a problem with connecting a wireless charger (cheap chinese one without datasheet) to a microcontroller (ATtiny85).
If the phone is not placed on the charger, there is 5 V in the signal, if the phone is placed on the charger and charging, there is 3.3 V.
I need this signal to be passed to the microcontroller with a digital input. However, it only responds to 0-1 V as LOW and 3-5 V as HIGH. How to convert the 3.3-5 V range from the charger to 0-5 V for the microcontroller?
I tried a Schmitt trigger, but don't know how to go low under 1 V.
simulate this circuit – Schematic created using CircuitLab enter image description here
The Microchip ATtiny85 GPIO pins are ST so this should be adequate.
A simple solution is a non-inverting HCMOS gate and a resistor divider. enter image description here
  • \$\begingroup\$ I'm not sure if this would work reliably. For \$V_{CC}=4.5V: V_{IH,MIN} = 3.15V, V_{IL,MIN} = 1.35V\$. Here the gate input is 3.11V and 2.05V for VG1 = 5V and 3.3V, respectively. \$\endgroup\$
    – Velvet
    Nov 22, 2022 at 14:54
