I am designing a device that uses a small 12V N20 geared motor. For convenience, I would like to power my device via micro usb. I intend to use a step-up boost converter to get from the supplied 5V to the necessary 12V to power my motor.
I’m wondering what it would take to power my device from a host device like a laptop instead of a USB wall charger. The motor has a rated current of 200 mA, but can draw up to 500 mA with a locked rotor. Assuming a max 2.5W (0.5A@5V), I believe I could get just enough power (0.2A@12V) for the rated torque. This assumes that my device can negotiate for the 500 mA max, which I understand can be very complicated.
- It seems many power sources don’t bother with the negotiation process and supply up to 500 mA by default. Am I overthinking this?
- If negotiation is necessary, is there a chip that will do this for me?
- Does my device need to handle overcurrent protection in the event the motor gets locked up for some reason, or will the host device automatically cut it off?
- Should any usb-powered device be capable of running off of any usb power source? In other words, is it common for usb-powered devices to be designed to run off of only a usb power brick with adequate current and not a host device like a laptop?
