This is one of the tasks in my BJT amplifier lab. I have to find impedance seen to the right from V1 which can easily be done by taking a frequency sweep and measuring \$\small \frac{V_1}{I_{C_2}}\$ at 1kHz. I also have to find the input and output impedances. Input impedance is also easy since I can just divide the input voltage by the current through it. But how to find the output impedance. I know I cannot use the traditional circuit theory method of killing the independent sources and adding a test source since that will change the biasing of the transistors. Also I need to measure it using LT Spice and not calculate it using small-signal analysis.
So what should I do here?
