I'm looking at the W66CP2NQUAFJ from Winbond. It has a couple of pins, namely CK_t_A and CK_c_A. In the datasheet, it says that these are differential pairs, but nowhere does it state which is the positive/negative line.
Does anyone know which is which?
  • \$\begingroup\$ Memory is standardized so its probably assumed you already know from the standard. \$\endgroup\$
    – DKNguyen
    Commented Nov 25, 2022 at 16:13
6
"t" stands for "true"; this is the positive (non-inverted) input.
"c" stands for "complement"; this is the negative (inverted) input.
From Winbonn W66BP6NB / W66CP2NQ 2Gb / 4Gb LPDDR4 data sheet page 5.
Clock: CK_t and CK_c are differential clock inputs. All address, command, and control input signals are sampled on the crossing of the positive edge of CK_t and the negative edge of CK_c. AC timings for CA parameters are referenced to CK. Each channel (A & B) has its own clock pair.
Even if it was not stated there, it is clearly seen from the timing diagrams. From page 86:
From Page 215:
8.3.2.5 Differential Input Cross Point Voltage The cross point voltage of differential input signals (CK_t, CK_c) must meet the requirements in Table 96.
The differential input cross point voltage VIX is measured from the actual cross point of true and complement signals to the mid level.
  • \$\begingroup\$ This is a good answer, very detailed for the specific part. But, I would rather accept @Jonathan S.'s answer, as it is more generic for memory and just EE in general. \$\endgroup\$ Commented Nov 25, 2022 at 23:11
