There footprint of a part has several pads connected to each other through a shared copper fill. How would I assign the shared copper fill to be associated with the pads it's connected to? The problem I'm facing is that when I do a copper filled zone in the PCB editor there is no way for me to assign a net class to that shared copper fill so there it becomes an island.
For example, pads 9, 10, 11 are all connected together through a shared polygon. The polygon itself doesn't have a pad name. I created a filled zone with 0 clearance and solid pad connections and fill but it still avoids the copper polygon.
What's the best way to fix this? Should I make a custom sized pad for, let's say pad 9, and shape it to match the current polygon?
Version: 6.0.9-8da3e8f707~116~ubuntu22.04.1, release build
