I bought a 400->230 V isolation transformer. I measure 'infinite' resistance between primary and secondary, like I expected. When I connect a variac/autotransformer to the secondary I can still measure some voltage on the output of either side leaving one of the leads unconnected. I also see a sine wave when connecting only one side of the probe to either output of the variac.
  1. Is this due to some stray capacitance and can this be called 'phantom voltage'?
  2. When I increase the output voltage at first this 'phantom voltage' goes up (to ~20-30VAC), later to go down again (to ~5-10V). How can this be explained?
  3. When I connect a microwave transformer to the output of the variac. It's output pole still shows a voltage when I increase the input on the variac (still with one of the measuring leads unconnected), but the mass of this transformer does not show any voltage. How is this explained in terms of wiring of the transformer. To my knowledge one side of the output is connected to the metal body of the transformer, is this incorrect?
  4. Is there any significant difference between what is called primary and secondary on an isolation transformer or can they safely be reversed?
  • 4
    \$\begingroup\$ You can't measure a voltage with one lead floating. \$\endgroup\$
    – Chu
    Nov 26, 2022 at 12:14
  • \$\begingroup\$ a 400 V to 230V isolation transformer is not a 1:1 turns ratio. Therefore you cannot interchange the primary and secondary windings and expect the same behavior. \$\endgroup\$
    – Barry
    Nov 26, 2022 at 13:33
  • \$\begingroup\$ @Barry No i would expect that if I use the secondary for input, I get 400 VAC at the 'primary'... \$\endgroup\$
    – Niels
    Nov 26, 2022 at 14:05
  • 4
    \$\begingroup\$ Please stop working with these components immediately. "I tried touching the output to check the isolation" in combination with "Microwave transformer" is a great recipe for painful death by electrocution. You NEVER touch any conductors in a high-voltage system, no matter if it's supposed to be floating or not. \$\endgroup\$ Nov 26, 2022 at 14:35
    \$\begingroup\$ The problem is that that's not safe either. If you have an isolation fault anywhere (and microwave transformers aren't great), your supposedly isolated variac will suddenly be at 2kV or so - enough to kill someone. The isolation of the variac will not hold up to the high voltage, making the entire metal casing of the variac live. And that's only one of the possible failure modes. You don't seem to be aware of all the potential dangers of such experiments. The probability that you will get yourself killed is uncomfortably high, so please stop. \$\endgroup\$ Nov 26, 2022 at 14:55
Voltage is a 2-node quantity. \$V_{ab}\$ means the voltage from node \$a\$ (the red lead) to node \$b\$ (the black lead). Sometimes voltages are written with a single subscript, as in \$V_{a}\$. In this case it is assumed that the voltage is relative to a reference node. It can then be said that \$V_{ab}=V_{a}-V_{b}\$. When you leave one lead (say it is node \$b\$) disconnected, the node is in the air where the probe is. When you touch the lead in the are the voltage at that point changes. Voltages measured this way are meaningless.
The oscilloscope is a voltmeter with the black lead connected to ground. The probe is similar to the red lead on a DMM.
You must understand that the meter display indicates the voltage difference from the red lead to the black lead.
There is capacitance between the disconnected probe and every other conductive object nearby. There is also interwinding capacitance. The meter is high impedance so observing a voltage is not unreasonable.
There is no such phantom voltage. All voltages are real, even the ones that are meaningless.
The capacitance of the disconnected lead is changing as you move around it or move it around.
When I connect a microwave transformer to the output of the variac. It's output pole still shows a voltage when I increase the input on the variac (still with one of the measuring leads unconnected),...
The voltage output is from one terminal (pole is not the correct term) to a second terminal. You cannot measure with one lead disconnected.
...but the mass of this transformer does not show any voltage.
Mass has nothing to do with with voltage.
Sometimes yes, sometimes no. You will have to read the datasheet.
You seem to have a misunderstanding of the nature of voltage and how to measure it.
Imagine that I want to measure the length of a box. I have a string that has millimeter markings on it. I holder the string to the left edge of the box and read 135mm. I go away and come back and hold the string against the left edge and get 199mm. I repeat this over and over and get variety of measurements that don't make sense.
I call a friend over and explain the problem. I suspect that there is something wrong with the string. She notices that whenever I hold the string to the box , the zero und is left unconnected, then tells me to connect the zero end to the right side and hold the string to the left side at the same time. I now measure 160 mm consistently over several measurements. I also notice that if I place an arbitrary point on the right side, then subtract the value from the left side, I also get 160 mm.
Distance is a 2-point quantity. So is voltage.
This is why the measured voltage between phase and ground tends to be around half the transformer output voltage. I can see why at first glance this may cause concern, as it appears that we have a high voltage to earth even via our isolation transformer. However no current will flow (and hence it is safe) if we make a connection between any phase and earth. All we do is now reference that phase to earth.
I think this souce is correct: Isolation Transformer. What you need to know
  • 4
    \$\begingroup\$ Hi, Since you asked the question, the only time you would write an answer is if you are writing your own final solution to your question. (a) In order to effectively mark the topic as solved, please consider "accepting" an answer (click the "tick mark" next to that answer, to turn it green). Note that you must wait 48 hours after you asked the question before you can accept your own answer, but you can accept another answer at any time. (b) If you didn't mean this to be treated as a final answer but wanted others to reply, it should be an update in the question. Thanks. \$\endgroup\$
    – SamGibson
    Nov 26, 2022 at 17:14
