I want take a look at the memory and at the elements inside the atmega1280. I compiled Ardupilot sketch and I uploaded it with an arduino.
I started avarice with the following command:
$ avarice --mkII --capture --jtag usb :4242
and I started avr-gdb
$ avr-gdb /tmp/build5831285936308447966.tmp/ArduPilotMega.cpp.elf
I typed:
(gdb)target remote localhost:4242
and this is the answer:
(gdb) target remote localhost:4242
Remote debugging using localhost:4242
0xfffffffe in ?? ()
when I do list it show me
#include <WProgram.h>
int main(void)
    init();
    setup();
    for (;;)
        loop();
    return 0;
That is not my ardupilot!
I don't understand why I get the ?? symbol after the target command and why I get a different source after the list command.
Could someone explain where is my error, how they work and the reason of those symbols? More important, how can I take a look inside of the atmega1280?
P.S.: I compiled with Arduino, so I compiled with the -g flag.
Edit: I used an unofficial jtagice mkii:
and I follow this guide for the setting http://www.diydronesafety.com/topic/72-articleundocumented-apm2x-jtag-technique-and-jtag-for-apm1x-using-only-the-redboard/
So mine is presented like this:
  • 4
    \$\begingroup\$ ... in fact that is what every arduino sketch looks like you simply implement setup and loop in a separate file than that one... \$\endgroup\$ – vicatcu Apr 4 '13 at 22:17
  • \$\begingroup\$ As viactcu suggests, everything looks fine. Try tracing into the setup() or loop() calls and see if it's as you expect. up. If not, you may have told the development-machine-side gdb to reference the wrong elf object. \$\endgroup\$ – Chris Stratton May 6 '13 at 1:19
-1
You should think about investing in JTAGICE MKII, it supports many Atmel device. When you use it with Atmel AVR Studio, debugging is a breeze and it allows you to look inside all the devices.
| improve this answer | |
  • \$\begingroup\$ So, are you saying that i can't do it without atmel avr studio? \$\endgroup\$ – DarkCoffee Apr 5 '13 at 15:25
  • \$\begingroup\$ AVR Studio is free and is easily the best debugging interface for Atmel chips. I would peruse through AVRfreaks.net too if you're looking for more help with this; I bet the forums there have what you're looking for. As a side note I have the JTAGICE3 and it was probably the best money I ever spent on a debugger. \$\endgroup\$ – tmwoods Apr 8 '13 at 3:14
