I'm working with 8 - 16 MTCH101 capacitive proximity sensors connected to one master MCU. Each sensor has a single output pin that is either HIGH or LOW.
Is there a general-purpose IC that I can use to daisy chain these sensors together to generate a serial value based on the output of each sensor? I could use a parallel-to-serial multiplexer, however, the sensors will each be on their own board and that would require each board to have a hardline to the multiplexer.
Ideally, there's just one bus that goes to each sensor and has a serial output at the end.
I could add a small microcontroller to each sensor board with custom firmware that does this. However, the 8-16 sensors are part of one module, and I'll be building 20+ modules, so a purpose-built IC would add one less thing to program and manage.
