14
I'm well aware of the best practices for charging lithium chemistry batteries, and how the charges themselves work.
I've never had a water tight explanation on why having a load on a battery during the CC phase is dangerous.
My understanding is that battery charging works as follows:
  1. Battery is charged at constant current, variable voltage
  2. When current flow reduces to 10% of capacity, charger switches to constant voltage (full voltage) to top the battery off
I know that if a load is present on the battery during the CC phase, the charger might not neccissarily detect that 10% threshold, my question is, why is this a problem.
Unless I'm mistaken, the charger achieves the constant current by increasing the charging voltage to the max charge voltage - e.g for 4S that would be 16.8V, it doesn't increase it beyond this.
So, you can't actually over charge the battery?
The battery voltage and charger voltage could be slightly out if there was a load on it, but it still wouldn't be over the max voltage as the charger (to my mind) does not do this.
    \$\begingroup\$ The danger is in the CV phase, not the CC phase. \$\endgroup\$
    – user16324
    Nov 29, 2022 at 19:33
4 Answers 4
11
If your charger outputs 1 A in CC mode, and has a 500 mA constant current load connected, then 500 mA goes to battery and 500 mA to the load. So the battery will also charge slower because only half the current goes into it.
When a battery has charged to 4.2 V per cell and the charger switches to CV mode, the battery current starts to drop, but the load will still take 500 mA.
So the charger never sees that the current has dropped to the 100 mA threshold to terminate charging, because there is always a 500 mA load connected.
The battery current may become zero, and it will be floated indefinitely at 4.2 V unless the charger has a safety timeout feature to cut off after certain time if the current has not dropped to a level when to stop charging.
So the load prevents the charger from working as intended.
To recap, battery is not full when CC mode changes to CV mode with 4.2 V on battery. It still takes in current. Battery is full when there is 4.2 V on battery and battery current has dropped to 10% of current and charging should stop here. If charging is not stopped, there still is current to battery, and this will overcharge and damage the battery. And overcharged and damaged lithium batteries are not safe, they can explode or burst into flames.
So if charger should stop when battery current has dropped to 100 mA, any extra current drawn from charger will make the charger to overcharge and damage the battery. If you draw even only 50mA of extra current, it means battery charging is not stopped when battery current is 100mA, battery will be float charged at 4.2V until battery charging current has dropped to 50mA if extra load draws 50mA.
    \$\begingroup\$ Current only flows if there is a difference in voltage. Once the battery is charged to 4.2 V, current will not flow from the charger to the battery, just from charger to load. \$\endgroup\$
    – Ben Bird
    Nov 30, 2022 at 17:26
    \$\begingroup\$ @BenBird yes that is true and I am sure Justme has not overlooked that fact. But floating a lithium ion battery at 4.2 V indefinitely is EXACTLY what the charger is supposed to avoid doing because it is universally acknowledged to be unsafe. It is not true that the battery current will be 0 pico amps. A small current will flow into the battery and over time degrade it. \$\endgroup\$
    – user57037
    Nov 30, 2022 at 17:41
    \$\begingroup\$ @BenBird Yes that is the point, a lithium battery gets damage if you float it, which is why it is bad and must never ever allowed to be floated. Sorry it was not explicitly mentioned in the answer. \$\endgroup\$
    – Justme
    Nov 30, 2022 at 18:54
8
Basically you want to charge the battery until the end of charge condition is reached (voltage >= Vthreshold and current <= Ithreshold) and then end the charge and let the battery rest.
The end of charge voltage is a compromise. It should be as high as possible to stuff as much energy into the battery as possible, but higher voltage makes it age quicker, and past a certain threshold it becomes dangerous. 4.2V is ideal for portable devices because you do want to store as much energy as possible. However, keeping it at 4.2V for an extended period of time will sorten its life: this happens with laptops that are constantly plugged ; after a year or two when you unplug it, battery life will be significantly shortened even though it has had few cycles.
As Justme said the extra load can prevent the charger's end of charge detection from stopping the charge, so it will float the battery at the end of charge voltage for a long time, which will shorten its life.
If you want to use a LiIon battery like a lead-acid battery or a capacitor, and float it to a constant voltage indefinitely while a load is drawing current, simply use lower voltage. So for a battery that reaches end of charge at 4.2V, you can set it to 4.05V. You will lose a bit of capacity, but it will last much longer at this voltage.
  • \$\begingroup\$ Ok this is a decent explanation, and confirms my thought process. Everyone seems to parrot that its dangerous without actually thinking about it. You cannot "over charge" the battery with this method (assuming of course the charger max voltage is 4.2 V per cell), but as you put it, you're keeping the battery at max voltage for extended periods of time which reduces the life span. I'm fine with that, as my application will be something along the lines of ------ next comment \$\endgroup\$
    – Ben Bird
    Nov 30, 2022 at 17:30
  • \$\begingroup\$ Device charges up and floats at full voltage for 14 hours, device is removed and then discharges for 10 hours.... repeat for 4 days and then charge and float Friday, Saturdfay and Sunday, repeat for 8 weeks. Then discharge completely, crush everything, mix with molten glass and bury for ever, about a mile under a mountain somewhere in Finland. \$\endgroup\$
    – Ben Bird
    Nov 30, 2022 at 17:32
  • \$\begingroup\$ Yeah in this case, no problem. Is it a radiation dosimeter or something like that? \$\endgroup\$
    – bobflux
    Nov 30, 2022 at 17:52
  • \$\begingroup\$ To the OP: a simple expedient might be to just float at 4.1 or even 4.0. This will give you about 80 or 90 percent of the cell capacity but you won't be floating at 4.2 and thus it should increase the safety margin. The probability of any 1 quality battery failing during the 8 week scenario you outlined is low, even if you float at 4.2. So then the question is, what if it does fail? Are you losing anything valuable? And also how many are you making? If 5 units, no problem. If 5 million, then play it safe. \$\endgroup\$
    – user57037
    Nov 30, 2022 at 22:26
That's not right. The charger limits voltage to the battery's peak rating (typically 4.2 V per cell). As a result the current automatically reduces due to resistances in the circuit (including internal cell resistances). During this time ~20% more charge is put into the battery as its internal voltage rises to meet the regulated charger voltage.
Li-ion battery manufacturers generally rate the voltage for maximum safe capacity, which is just below the point of 'overcharge' where it will be damaged. But if held at this voltage for long it will degrade much faster, particuarly at high temperature. Therefore chargers which might be connected continuously often cut off when the current falls to ~10% of the 'constant' charge current, allowing the battery voltage to settle and go down as it is discharged by the device.
  • \$\begingroup\$ First part - you're splitting hairs on a very general explanation of something, which isn't relevant to the question. Second part - yes, i understand that the battery will be degraded much faster, this is not an issue at all as device lifespan will be 6 weeks maximum. Temperature will also be constant. \$\endgroup\$
    – Ben Bird
    Nov 30, 2022 at 17:35
The real simple explanation is that in the early days of lithium ion batteries it was discovered empirically that floating the cells at 4.2 V indefinitely sometimes led to cell failure which could include venting and ignition. It then became a best practice to avoid floating at that voltage.
Any set of circumstances which leads to the cell being kept at 4.2 V indefinitely is outside of best practices.
Lowering the float voltage to 4.0 V or 4.1 V probably reduces the hazard (although I have never seen a cell datasheet that endorsed this practice).
