Why is it not practical to connect the two drains of the MOSFETs together? Is it not practical to connect the source of one MOSFET to the gate of another?
7\$\begingroup\$ It's practical (well, you'd need a resistor to suck away the gate charge for it to turn off again, but Darlingtons often have that), but what benefits do you expect to gain? There are more useful and interesting connections of two MOSFETs. \$\endgroup\$– Spehro PefhanyDec 2, 2022 at 11:03
1\$\begingroup\$ @SpehroPefhany: Adding a resistor to bleed off the gate charge of a MOSFET negates one of the major advantages a MOSFET would have over a BJT. On the other hand, an IGBT is in many ways similar to a Darlington whose input BJT is replaced by a MOSFET. \$\endgroup\$– supercatDec 2, 2022 at 20:48
The main advantage of Darlington and Sziklai BJT pair arrangements is that you get the product of the current gains of the two transistors.
But MOSFETs already have essentially infinite DC current gain, so you don't typically use these configurations at low frequencies.
The above is valid for low frequencies, but when considering fast dynamics, there are of course situations where you use one small MOSFET to drive the gate of another larger one, to speed up operation. Just think of gate drivers.
\$\begingroup\$ @tobalt May I ask: What is the "main advantage" for having the "product of the current gains"? \$\endgroup\$– LvWDec 2, 2022 at 15:04
7\$\begingroup\$ @LvW That you can achieve a much higher current gain than with a single BJT? Say you want to switch a 10A load using a microcontroller port which can source a few milliamps. That means you need a beta in the thousands. BJTs typically have betas in the low hundreds, which is not enough on its own, but a hundred times a hundred is plenty enough. \$\endgroup\$– TooTeaDec 2, 2022 at 15:16
\$\begingroup\$ @LvW TooTea mentions a good example. Another is BJT power stages such as in linear regulators. Or did your comment address anything else such as wording? If so, please feel free to make it more clear, because I currently don't see how it could be misunderstood \$\endgroup\$– tobaltDec 2, 2022 at 15:39
1\$\begingroup\$ @LvW Bit also linear high current designs.. Think of LM317 regulators, audio Power amps. Or think of Darlington input stages where you want to present a minimum load to signals, such as LM339 input Darlington. \$\endgroup\$– tobaltDec 2, 2022 at 16:15
2\$\begingroup\$ Mirroring your answer, one place that this does occasional show up directly is VLSI, because gates are leaky at those scales, and so MOSFETs have nowhere near infinite current gain. \$\endgroup\$– TLWDec 3, 2022 at 19:40
I cant answer the question why you don't use them.
But there are cases where MOSFET are used in darlington like configurations. It's apparently used in low voltage applications to reduce power consumption.
It's mentioned for example in the research paper Design of Low Voltage, Low Power (IF) Amplifier Based-On MOSFET Darlington Configuration (in the abstract) (direct Link to pdf of the paper)
5\$\begingroup\$ Does anyone besides that paper call the circuit a MOSFET Darlington? To me it looks like a common-drain and a common-source stage in series. \$\endgroup\$ Dec 2, 2022 at 12:14
2\$\begingroup\$ @LarsHankeln the paper cited in this answer makes me cringe. I guess it's expected seeing from which venue is coming from... \$\endgroup\$– ErnestoGDec 2, 2022 at 13:05
1\$\begingroup\$ I wonder who will use such an amplifier. Unless it's an experiment to show that a non-amplifying 1st stage will give you a worse input referred noise. \$\endgroup\$– ErnestoGDec 2, 2022 at 13:07
1\$\begingroup\$ My first impulse was the same as the one from @LvW below. But my research lead me to that paper. And the wording in "Conclusion" suggests that it makes sense in IF stages in RF applications. \$\endgroup\$– kruemiDec 2, 2022 at 14:39
3\$\begingroup\$ @kruemi literature is full of new name conventions (in this case, for circuits) that authors try push hard to stick among the community, and this is not my own speculation, this has been said to me by an IEEE fellow. In the paper you share, the author tries to lure people into thinking he's "created" the MOS version of the darlington pair, but, in fact, he's just cascaded a source follower with a common-emitter amplifier with series-series feedback. \$\endgroup\$– ErnestoGDec 2, 2022 at 22:42
Why should anybody use a Darlington combination with FETs? For which purpose? In this context, it makes sense to ask for the benefits of a BJT-based Darlington configuration.
Answer:
- The transconductance of the Darlington stage - most important for the voltage gain - is only 50% of the transconductance of a single BJT (with the same collector current). So - this offers no advantages.
- The input impedance of a BJT-based Darlington stage is twice the input impedance of a single BJT (same DC operating point). This is an improvement - however, only in case of bipolar transistors. Due to the large FET input impedance this aspect seems not to be very important.
To expand on tobalt's mention of gate drivers, an example:
On page 4, note the diagram specifically shows dual N-channel outputs. It, uh, erroneously shows their gates tied together, which would make one hell of a short circuit when 'on'... a perfect example of manufacturers not inspecting their own damn diagrams -- always take them with a grain of salt...
But, assuming they mean that in a less literal sense (signal flow, polarities resolved in a useful way)... they're using a source follower to drive the output high, and common-source to drive it low.
This is in agreement with the characteristics (page 3), VOH max 1.2V from VBS or VCC respectively -- and this at zero load current, so presumably it will be even lower than this in practice.
Having measured one myself, it does indeed lose about two volts from the supply. Drive is strong below there (i.e. for most of the 0 < VO < VOH range) so it's quite effective, as long as you don't need those extra couple of volts on top.
Why choose this design? NMOS perform better than PMOS: lower RDS(on) per unit (gate / drain) capacitance, so the rising edge can be stronger and faster. They might also have trouble making PMOS in the HVIC process (the high-side circuitry is indeed on the same silicon chip, isolated by a huge diode junction it's built on top of); though it seems likely it is indeed CMOS on both sides, and this is more for performance reasons.
Earlier/smaller drivers in this family, like IR2101, are fully CMOS, i.e. a PMOS pull-up driver -- but only rated for ~200mA output current, so, they are unsuitable for high power and fast switching circuitry. Presumably, they didn't want to spend more die area on these transistors; perhaps the same limitation applies to the IR2181.
There are other versions of drivers, such as onsemi (née Fairchild) which use bipolar transistors to boost the drive strength; in this case you get effectively a hybrid Darlington, with an NPN follower into a common-source MOSFET.
Note that those are all switching applications, so all the effort is strictly about shoving around gate charge through large voltage swings (~10V). The beauty of general transistor applications is almost all in the analog domain.
In analog terms, the bipolar Darlington is excellent for reducing input current, at modest expense to VCE(sat) (and usually speed as well). This applies over much of the useful range of the pair (i.e., over a huge current range, and from DC to medium frequencies).
For MOSFETs, we can think in terms of the first (driving) transistor having some transconductance, and by reciprocity, its source terminal having a source impedance around 1/gm, which makes an RC time constant with the driven gate's capacitance. All together, a high impedance node can drive a much larger transistor while keeping bandwidth high, at some expense to the bias current that must be drawn through the driver transistor. An external bias resistor (or CCS or whatever) is required, since transistors don't transconduct without bias current.
The same analysis applies to BJTs of course, but the driver transistor's quiescent current can be the driven's base current. Often, a B-E resistor is added anyway, to speed turn-off, and to bias the driver transistor (in the same way as the MOSFET case requires), keeping it fast even at low currents.
