I am trying to implement counter using Verilog HDL
output reg testLED;
reg [30:0] counter;
reg [30:0] sec = 0;
always @ (posedge clock50MHz)
begin
     if(sec>10) testLED = 1;
     counter<= counter+1;
     if (counter == 30'd50_000_000) begin
        counter<=0;
        sec = sec +1;
     end
end
However, this code is not working properly. testLED lights up immediately after startup. Moreover, when I tried to do it using assign, the counter worked properly.
output testLED;
reg [30:0] counter;
reg [30:0] sec = 0;
begin
    counter <= counter+1;
    counter<=0;
        sec = sec +1;
    end
end
assign testLED = (sec>10) ? 1 :0;
What is the reason of this behaviour and how make the counter work without "assign"?
  • \$\begingroup\$ When you run a simulation, what is the initial value of counter? \$\endgroup\$ Dec 4, 2022 at 13:37
  • \$\begingroup\$ I haven't tested in simulator. I am using DE10-Lite FPGA board. \$\endgroup\$
    – nai1ka
    Dec 4, 2022 at 14:19
You have not initialized 'counter', but that's not the only issue.
The two statements don't do the same thing. If you replace
With
testLED <= (sec>10) ? 1:0;
(and deal with initializing 'counter') then it should work. Note the use of a non-blocking assignment <= in the sequential block, also note that a value is assigned on every single clock edge. If you don't assign a value on every edge, a flip-flop is needed to retain the previous value (in this case, an uninitialized value).
You could alternatively add a combinational block using a a blocking assignment:
always @ (*)
begin
      else testLED = 0;
end
or even
always @ (*)
begin
   testLED = 0;
end
They are equivalent give or take one 50MHz clock edge.
