6
Here's a picture of two chips next to each other: The ATTiny85 and the nRF24l01+. The ATTiny85 will fit in a standard 8Pin DIL, but the nRF chip won't because the connectors are more tightly spaced together. Does anyone know if there is any "standard" the connections on the nRF24l01+ chip are following? 2x4 pin single in line?
    \$\begingroup\$ The one on the left isn't DIL, it's 0.1" headers. \$\endgroup\$ – pjc50 Apr 5 '13 at 11:48
    \$\begingroup\$ The one on the left isn't exactly a chip, either. The 0.1" pitch headers it uses are quite common board-to-board connectors. \$\endgroup\$ – Brian Drummond Apr 5 '13 at 12:40
6
Dual In-Line, as applicable to IC packages, is a standard, with the pin pitch of each row being 0.1 inch, and the separation between rows (the dual part) being 0.3 inches (JEDEC MS-001) for small pin count packages.
There is also a 0.6 inch row separation DIL package (JEDEC MS-010), for large pin counts. These are commonly known as Wide-DIP ICs.
The nRF device shown is not actually a standard IC package, it just uses a standard pitch 0.1" pin pitch (along both axes) connector. It is not designed to fit into a DIP IC socket. Instead, one would use a dual-row female pin header if soldering onto a board is not desired:
Dual row female pin header (source)
Edit: I just found out that apparently there are also less common 0.4 inch and 0.9 inch row separation packages, though I have never seen one. Also known are 0.75 inch row spacing packages with a 0.07 inch pin pitch.
