I need to connect a relay to my old truck to turn on the "soon to add" electric fans.
The ECM has an engine coolant temperature sensor that uses the output resistance to determine coolant temperature.
From the service manual, I have this data:
engine coolant temperature sensor output
If you can not see the pic above:
__Condition________________|_Engine coolant temperature decided
Just as ignition switch is |
turned ON or Start_________|_20°C (68°F)_______________________
More than 6 minutes after  |
ignition ON or Start_______|_80°C (176°F)______________________
                           | 20 - 80°C (68 - 176°F)
Except as shown above______| (Depends on the time)_____________
So, is there a way to get some sort of Relay that would turn a switch ON when Resistance translates to a certain value (like 185°F or so)?
EDIT More Pics!
diagram 2
engine coolant temp values
    \$\begingroup\$ "when a Voltage gets to a certain value (like 185°F or so)?" Voltage is measure in Volts, °F is a unit of temperature. So I'm not sure what you mean? \$\endgroup\$ – user17592 Apr 5 '13 at 17:54
    \$\begingroup\$ Ah, I see. I'm not sure what would solve your problem, perhaps a zener diode. But that's for the experts to say, I'm not sure what's the appropriate way to do this. \$\endgroup\$ – user17592 Apr 5 '13 at 18:00
    \$\begingroup\$ Oh, resistance. Then a zener diode won't be the solution, I think. Anyway, not my field of expertise, so let's wait for the expert to stop by. \$\endgroup\$ – user17592 Apr 5 '13 at 18:02
  • \$\begingroup\$ Thanks for pointing out the issues, though. :) \$\endgroup\$ – jp2code Apr 5 '13 at 18:02
    \$\begingroup\$ I think you're looking at a comparator with hysteresis circuit circuit, where you would have a voltage reference(resistor and zener) and a voltage divider circuit with a resistor and your temperature sensor(in series). You need the hysteresis on the comparator other the relay would "chatter" which is not a desired condition. I just do not know if you're looking at having this connected to the ECM while is connected to your control circuit for the fan \$\endgroup\$ – Kvegaoro Apr 5 '13 at 19:17
If you don't need a lot of precision in your circuit, you can build a simple voltage divider as follows
If you calculate the values in such as way that the voltage at output reaches the relay threshhold voltage, then when R1 get low enough to signal high temperature, the relay driven off the output will switch on. I think most mechanical relays are not very precise with respect to on-volate, so I would consider a solid-state relay for this.
As an example, lets say you want your fan to turn on above 50 degrees (1k sense resistence), and your relay operates at 5V. Given that for a voltage divider \$V_{out}\ = \dfrac{R_{2}}{R_{1}+R_{2}}\$, we just plug in all the values to get the unknown:
5V = \$\dfrac{1K}{1K + R_2}*12V\$
\$R_2\$ = 1.4K, so you use a 1.5k Ohm resistor. The current losses in this voltage divider are only 4.8mA, so it isn't like you are throwing away a lot of power as heat. On the other hand, your triggering resistance is 1K, so at 12V you can only supply 12mA of current to the relay. This will be insufficient for most mechanical relays, but should be OK for solid state relays (SSRs).
In general, environmental sensors are just that. They consist of some material that reacts to the particular parameter being sensed, e.g. temperature, pressure, humidity, etc. In most cases, the sensor material reacts to change an electrical quantity. In the case of a thermistor, it is resistance versus temperature. For a thermocouple, it is voltage versus temperature. For a pressure sensor, it is often resistance (usually in a bridge configuration) versus pressure. In all of these cases, additional circuitry is used to process the material change to convert it into something more useful for either displaying the measured quantity and/or using it to perform a function such as switching a relay or turning on an indicator light, etc. This additional circuitry is needed because most sensors do not have enough energy output to directly power a display or a relay. Also, the output of most sensors is not linear and/or have an offset so mathematical manipulations are needed to convert it into useful information such as temperature in degrees or pressure in psi,etc. These days, the output of most sensors eventually inputs to a processor which decides whether the indicated value requires doing something like driving a relay to turn on fan and/or setting an audible or visible alarm.
  • \$\begingroup\$ Yes, I understand I have a sensor and that I need to add a relay. The question was "How", since I have a variable ohm value to trigger with. \$\endgroup\$ – jp2code Apr 7 '13 at 21:16
