I have an Atmel TS87C51U2 8bit microcontroller with dual UART.
I want to program the IC with a serial to USB module (TTL) or with an Arduino.
Is it possible do this? Which program do I need?
  • \$\begingroup\$ Please verify that this is the datasheet of the part that you're talking about, and if so, edit your question to include this link. \$\endgroup\$
    – TimWescott
    Dec 11, 2022 at 17:14
  • \$\begingroup\$ Not exactly, I will edit the post and send the data sheet is it for ATMEL company. \$\endgroup\$
    – Qteam
    Dec 12, 2022 at 19:27
Have a look further on into the Atmel TS87C51U2 datasheet, at section 9.3 (below).
That makes it clear that the internal EPROM requires an external programmer, which must be capable of providing a 12.75 V programming voltage. The external programmer must put the MCU into a programming mode the manipulate the MCU pins to programme the EPROM then read it back to verify programming success.
The EPROM non-volatile technology is the predecessor of the convenient Flash EPROM. The latter is now used plentifully in MCUs and supports in-system programming and erasure at the normal MCU supply voltage.
In-system EPROM reprogramming requires the ability to overwrite existing data with all values of new data. That isn't possible with EPROM anyway, which requires exposure to ultra-violet light to erase it. That had to be shone through a window in the part package for 20-odd minutes.
  • \$\begingroup\$ It appears the memory is One-Time Programmable (OTP). There is no window for erasing so no need to worry about that. \$\endgroup\$
    – Justme
    Dec 11, 2022 at 19:34
  • \$\begingroup\$ Thanks so much for your response and time, Can you introduce a programmer that can do that? \$\endgroup\$
    – Qteam
    Dec 12, 2022 at 19:21
  • \$\begingroup\$ @Qteam, you're very welcome but finding a programmer is an Internet search job best done by yourself, as you know your budget, application and so on. \$\endgroup\$
    – TonyM
    Dec 22, 2022 at 21:37
If, indeed, that is the data sheet, then no -- it's an EPROM part, which means that during programming it won't be operating in a normal fashion. You basically need an EPROM programmer. Moreover, you need an EPROM eraser (and you need to have a part with a window) to blank out the chip in preparation of programming.
    \$\begingroup\$ The part is one time programmable and can't be erased. \$\endgroup\$
    – Justme
    Dec 11, 2022 at 19:35
  • \$\begingroup\$ Doesn't the 7 in 87C mean that it's EPROM? I was assuming it was the 83 part that was OTP. But -- sure. Either way, you can't just hook up a serial port to it and do the deed. \$\endgroup\$
    – TimWescott
    Dec 11, 2022 at 21:17
