I have a PIC16F877A microcontroller with a 19.6608 MHz crystal, wired for 12V ICSP. I can reprogram the chip just fine, and it runs almost flawlessly (it's blinking an LED right now as I type). Only thing is, the PIC seems to latch up or stop its oscillator when I get up from my chair and touch the metal frame of the table it is sitting on. I sit back down, touch the metal frame again, and the PIC starts blinking the LED again. Sometimes it takes more than one "cycle" to get the PIC started again. Weird...
I made sure to select the right oscillator mode (HS), disable the watchdog timer, set unused pins to outputs, use decoupling capacitors, etc. I made sure I selected the correct capacitors for the crystal I'm using.
Any suggestions as to the cause of this flakiness?
    \$\begingroup\$ In the year 2013, Microchip will sell you a microcontroller that has a built-in oscillator. \$\endgroup\$ – Kaz Apr 5 '13 at 22:13
    \$\begingroup\$ Can you post a picture of how you built this? PCB? Breadboard? \$\endgroup\$ – Kaz Apr 5 '13 at 22:14
  • \$\begingroup\$ @Kaz Build yourself a clock or try RS232 with a built-in oscillator and tell me how it goes. \$\endgroup\$ – user1354999 Apr 5 '13 at 22:55
    \$\begingroup\$ I built a clock with an external osc. recently! Problem is, it stops whenever I touch the desk ... \$\endgroup\$ – Kaz Apr 6 '13 at 0:55
  • \$\begingroup\$ @user1354999 Some MCUs do quite well with internal oscillators for serial communications. The AVR XMEGA series definitely work reliably for this purpose. \$\endgroup\$ – Anindo Ghosh Apr 6 '13 at 5:55
The most likely culprit is the reset input is not pulled high (or low, cannot remember) with a resistor to keep noise from triggering it. Look at the default circuits for PIC MCUs for the reset input.
    \$\begingroup\$ +1. The reset input in question is the MCLR pin (master clear, active-low), which needs to be pulled high. See section 14.4 of the 18f87xA datasheet. \$\endgroup\$ – Chris Johnson Mar 2 '14 at 0:15
