I found in this book at the page 271 a definition of the source follower input/output swing ( that i didn`t know as:
$$ V_{in-pp} = V_{dd} - ( Vt + 2.V_{ds-sat} )$$
I tried to understand how to calculate this paramater (I've tried to consider the condition for having the MOSFET in saturation Vds > Vd-sat and active Vgs > Vt), but I didn`t arrive to the same result. Considering: Vds > Vd-sat
and
Vin= Vout + VGS
I obtained
Vout < Vdd - Vd-sat
or equivalently
Vin < Vdd +Vgs - Vd-sat
Can somebody help me?
Book Name: Analog/RF and Mixed-Signal Circuit Systematic Design (pag271) Schematic: enter image description here
  • \$\begingroup\$ Please show us all of your work. \$\endgroup\$ Commented Dec 12, 2022 at 12:09
  • \$\begingroup\$ I change a little bit the question adding what i was trying to do.. \$\endgroup\$
    – Mxm89
    Commented Dec 12, 2022 at 18:07
  • \$\begingroup\$ Seems incorrect to me...Should be Vdd-2Vdsat. \$\endgroup\$
    – sarthak
    Commented Dec 12, 2022 at 21:36
We can arrive at their answer by adding the following assumptions, which are reasonable enough though not universally true:
  1. \$V_{in}\$ can never go above \$V_{DD}\$ or below ground.
  2. The current source \$I_b\$ needs headroom of at least \$V_{dsat}\$.
  3. We can approximate \$V_{gs} = V_{dsat} + V_{t} \$
Then the maximum value of the input is just \$V_{DD}\$.
The minimum value of the output is \$V_{dsat}\$, so:
$$V_{in,min} = V_{GS} + V_{out,min} = (V_t + V_{dsat}) + V_{dsat}$$
Thus:
$$V_{in,pp} = V_{DD} - (V_t + 2 V_{dsat})$$
