I'm in the process of designing a motion control system using RS485 and whilst we've generally made things work in the past with a more trial and error approach, in the interest of doing things right I'm trying to figure out what is the best practice exactly when it comes to ground connections.
I've been reading what I can find which seems relevant about RS485 ground connections but I'm uncertain about what exactly I should be connecting the signal ground to in the system I'm working on where there's multiple devices.
The motor drivers I'm using share a common signal and system (power input) ground, and the RS485 interfaces we're currently planning to use have shared chassis ground and signal ground.
As both signal grounds connect to a common ground at the RS485 interface, will the stepper motor drivers (through their shared grounds back to the interface) not cause loads of noise on this ground?
Where would be the appropriate place to connect these signal grounds (and so the connected DC neutral) to the AC ground in this system, if I presumably should do so?
You'll have to forgive me as I'm not an electrical engineer by training so am trying to figure out what I can, but any advice would be massively appreciated if there is anyone out there who would be able to advise!
And for reference all RS485 pairs are twisted from start to finish and all AC grounds can be assumed to be connected to the same.
And apologies if I am just completely of track / in over my head...
