So I'm trying to make a pulse sensor using TCRT5000 IR sensor and arduino UNO (giving out 4.8V really from 5V pin) (Baud Rate 19200), and I'm supposed to get a pulse plot like this
As you can see, absolutely no pulse is noticeable.
Below are some essential points:
In the phototransistor stage, I don't understand the symbol with the Arrow on the extreme left, I thought it was a Pot set to 1K Ohm so I used a 1K resistor between the 150 Ohm resistor and +5V.
My 1uF capacitor in the second stage is tantalum. My second capacitor, the 4.7uF, is electrolytic.
The schematic says the pin 11 of the LM324 should be connected to -5V, since I don't know how to get -5V out of Arduino I just connected it to GND on Arduino.
I did not have a IN4004 diode so I used a IN4007.
Where am I going wrong?
