I have a desktop computer with an Asus mainboard TUF_GAMING_B550-PLUS and a Raspberry Pi 4.
I log in remotely to the computer, but unfortunately from time to time it has an operating system issue, freezes, and has to be reset.
I want to do this remotely via the Raspi, as this is much more stable, "always on", and also remotely reachable.
I thought of getting a 5 V/230 V relay but this seems impracticable as the relays I can find would need a proper case and I would need to tamper with the 230 V power supply cable of the computer.
So I am thinking whether I could use the onboard power reset functionality of the computer mainboard.
In the manual of my Asus mainboard I can find the following description and sketch (see below):
My question is: does it make sense to reset the main-board in that way? If yes: how do I achieve this?
- Could I just take two cables and connect both devices, the Raspberry Pi's ground and one of its I/O outputs?
- Do I have to connect them with RSTCON# and GND?
- Would grounding RSTCON# reset the main-board?
Main-board description:
- Reset button (2-pin RESET)
This 2-pin header is for the chassis-mounted reset button for system reboot without turning off the system power.
