Beginner question: I have a sensor board which has 6 solder pads (in parallel to each other, just a line of 6 pads), but no holes. Do there exist any connectors (like molex) that allow to fit the connector to the board? I didn't find any suitable connectors, but maybe I am using the wrong search terms. It seems all connectors require holes in the board.
Or do I simply have to solder the (flat) wire directly onto the board solder pads?
EDIT Here is a picture of the pads. The distance between the center of the first and last pad is 7.5 mm (I made a measurement error before). The solder pads are in the middle of the board, not near the edge.
