I am beginner in Verilog. So I am confused in coding in Verilog. Can I use one module in another module?
module pn(
  input p,
  input n,
  input clk,
  output reg q
  initial begin
    q = 0;
  end
  always @(posedge clk) q=(q&n)|((~q)&p);
endmodule
I want to use it in following module
module ic2323(
  input p0,
  input n0,
  input p1,
  input n1,
  input clk,
  output q0,
  output q1,
  output x
endmodule
Is it possible?
EDIT:
 x=q0~^q1;
this code gives error
Reference to scalar wire 'x' is not a legal reg or variable lvalue
Illegal left hand side of blocking assignment
  • \$\begingroup\$ do you have the x=q0~^q1; inside an always block, or in an assign statement? If it's in an always block, you need to declare reg x first. \$\endgroup\$
    – The Photon
    Commented Apr 7, 2013 at 14:58
  • \$\begingroup\$ yeah, you are right. i noticed problem \$\endgroup\$ Commented Apr 7, 2013 at 15:02
Sure, if you couldn't build up a hierarchy, HDLs would be rather limited.
For example, you could have:
module ic2323(
  input p0,
  input n0,
  input p1,
  input n1,
  input clk,
  output q0,
  output q1,
  output x
  // Instantiate a pn for p0, n0 and q0.
  pn pn_a(
    .p   (p0),
    .n   (n0),
    .clk (clk),
    .q   (q0)
  // Instantiate another pn for p1, n1 and q1
  pn pn_b (
    .p   (p1),
    .n   (n1),
    .clk (clk),
    .q   (q1)
  // XNOR the two outputs together
  assign x = ~(q0 ^ q1);
endmodule
  • \$\begingroup\$ when i am doing expression for x, verilog complains that x is legal reg \$\endgroup\$ Commented Apr 7, 2013 at 14:19
  • \$\begingroup\$ x=(pn_a.q)~^(pn_b.q) in this statement \$\endgroup\$ Commented Apr 7, 2013 at 14:26
    \$\begingroup\$ You shouldn't refer to the instance ports directly, you need to refer to the signals you've connected to them. For example, assign x = ~q0 ^ q1. \$\endgroup\$
    – Dave Tweed
  • \$\begingroup\$ sorry, but it didn't solve problem. when i do as you said, it complains about the same problem \$\endgroup\$ Commented Apr 7, 2013 at 14:36
    \$\begingroup\$ You should edit the question to add a followup that shows the complete code for the second module that you're now using, along with the exact error message that the tool is giving you. \$\endgroup\$
    – Dave Tweed
    Commented Apr 7, 2013 at 14:39
