I am using a RS232 level shifting board with a raspberry pi. The board is connected to the pi using VCC, ground, RxOut->UART-Rx and TxIn->UART-Tx. I try to avoid buying a null-modem-cable, can I just switch the jumpers between the pi and the level shifting board?
Switching the RX and TX connections to the logic-level side of the board will not change the RS-232 level input to an output or vice-versa.
Instead you'll be connecting an input to an input (useless) and an output to an output (useless, and possibly harmful).
We don't know which board you have, but changing wiring on the board is wrong solution, and it still won't change the connector gender and it won't change which pins a are inputs and outputs on the connector.
So if a null modem cable has correct connectors then you should buy one.
Also small null modem plugs exist to adapt a normal cable to a null modem cable.
If you anyway need some DE-9 connectors and a cable, you could just buy correct connectors for the job.
No, the RS22 level shifters are unidirectional. if the connector has the wrong pinout you'll need to adapt that. "dupont" wires will work in a pinch.
