I'm trying to figure out how to create the GND layers for a PCB with an LM4612 buck converter module. The datasheet says a bunch of seemingly contradictory things:
- "Place a dedicated power ground layer underneath the unit."
- "Use a separated SGND ground copper area for components connected to signal pins. Connect the SGND to PGND underneath the unit."
Follow this example layout and corresponding schematic:
Here are the contradictions:
Even though they say to place a dedicated PGND underneath the unit, what they show in the diagram is a PGND underneath the top and bottom parts of the unit and an SGND underneath the middle part of the unit.
When it says "connect the SGND to PGND underneath the unit," doesn't this just turn both SGND and PGND into a single large generic GND layer? If so, why have separate copper at all? Why not just one GND layer covering everything? So, maybe they mean to connect SGND and PGND through a capacitor? (though they certainly don't say this explicitly anywhere)
My questions are about which pieces of advice to follow:
- Should I have two coppers as shown in the PCB diagram, SGND and PGND, and just short them together somewhere not shown in the PCB diagram to make one unified P/S-GND layer?
- Or should I just ignore the PCB diagram and do a single uninterrupted GND layer across the whole PCB without distinguishing SGND from PGND?
- How do PGND and SGND relate to the digital logic GND layer in my circuit? Are these physically separate layers of the PCB? Or just regions on one ultimately unified GND layer in the PCB stack?
