I'm currently rough drafting a RF/microwave pcb which I hope will be fairly wideband, from Mhz to possibly 6-7GHz. (not sure if it's possible). Anyway, when laying out the various components I find that many of the devices have different pad sizes, so there's no way to adjust the board or CPW to match all the different pad sizes. The distances between these pads will be small except for a short run of about 7mm to an RF switch. My question is, should I bother tapering the connections to the varying pad sizes to avoid abrupt changes, or does it not matter for short sections like this (~1mm between pads)?
The board will be a 4-layer with Er of 4.6. For 50 ohm impedance, the grounded CPW track width was calculated to be 0.35mm. This is smaller than all the components except for the RF switch which has 0.3mm pads. The SMA connector, 402 and 603 all have different but larger pads. There is another board option that is thinner, but the track width came out to 0.2mm which seems like it would make things worse. Anyway, I started adding tapers in the top path, but wanted to get some opinions here before moving on to the rest of the board.
Here is the layout I started: (no via fence yet, and pardon the 3D, it was the only way I could export)
There are two SMA connectors on the left, each going to a TVS diode and 2nd-order high pass filter, and on to the RF switch in the center.
Additional info: The TVS will have a capacitance of < .07pF and the L1/2 inductors are about 5uH, which is why I cannot use a smaller SMD.
Update: For others who might run into the same issue, here is the updated layout using the advice here:
