I want to control a motor's direction electrically. When the input is a zero, I want it to go one way, and a 1, the other way. The only way I can think of this is a solenoid with a spring attached to a DPDT reverse switch wired to the motor, so when theres current, the switch moves one way, and none it goes to it's original position. This is very inefficient and bulky, so is there a way to control the direction electrically? I prefer transistors and common electronic parts, but if I have to get a chip or something, it'l do.
    \$\begingroup\$ H-bridge (of fullbridge) is the name of the part you are looking for. You can build such things out of 4 MOSFETs \$\endgroup\$ Apr 7, 2013 at 21:07
    \$\begingroup\$ I agree with @angelatlarge but what motor voltage and current are you expecting. The circuit you are describing is called a relay. Most have DPDT capability so you can do a reverse change when you drive the coil - it isolates the control circuit from the motor too so it works on ac power line stuff. \$\endgroup\$
    Apr 7, 2013 at 21:13
  • \$\begingroup\$ I don't know the exact current, but 9-12 volts and probably less then a half an amp, so the MOSFET stuff should be good for it \$\endgroup\$
    – skyler
    Apr 7, 2013 at 21:15
  • \$\begingroup\$ Can an H-bridge be made out of p-channel MOSfets? \$\endgroup\$
    – skyler
    Apr 7, 2013 at 21:16
  • \$\begingroup\$ Yes, but you wouldn't want to. Conceptually simple is P channel on the high side and N channel on the low, though N channel devices work enough better that designers often jump through the hoops necessary to use them on the high side too. Inverting those tricks to use P channel on both would be possible, but not advantageous. \$\endgroup\$ Apr 7, 2013 at 21:17
You want to use an H-bridge, which is nothing more than four electronic switches hooked up in a nifty way that lets you change the direction of current through a motor. THIS is a pretty nice review.
enter image description here From http://www.mcmanis.com/chuck/robotics/tutorial/h-bridge/
Don't try to build one- buy one like the SN754410. You need to be a little careful if you see "half bridge". Two half bridges are used to make a full H-bridge. That chip has four half bridges.
