8
The picture below is an excerpt of Figure 2 of a DC/DC boost converter (see PDF here). It is part of a capacitance multiplier. What is the purpose of this (anti-parallel) diode between emitter and base of the transistor? I couldn't find this in any literature for capacitance multiplying.
11
The diode protects the BJT (inverted BE voltage) assuming the input voltage disappears.
Output capacitors can then discharge through the diode ... and the 500 Ohm safely.
For completeness, I simulated another configuration like this one (big output capacitor).
Check the currents without or with an added diode (currents through BJT). enter image description here
  • \$\begingroup\$ Great insight and demonstrations about spiking backwards the Base-collector current. I haven’t thought about that and your answer also clarified that. \$\endgroup\$
    – EJE
    Jan 27, 2023 at 21:03
  • \$\begingroup\$ It is a real pleasure. Thanks. \$\endgroup\$
    – Antonio51
    Jan 28, 2023 at 0:06
6
Probably to protect the transistor. Most BJTs will only tolerate -5 or so volts VBE.
