I need some help identifying two components in this RF circuit. I have spent quite a bit of time searching for either, who makes it, or what exactly they do, but no luck. Maybe someone here knows something about them.
The main component in question is the metallic blue package labeled 9413 J7DN. I am also unable to locate anything on the other two circled components (they are the same, just different markings.) Hopefully figuring out one will aid in narrowing down the others. I am unable to probe anything until an additional power module for the board arrives.
The circuit is the second of four down conversion stages from mm-wave to digital. This 2nd I.F. has two separate signals; both are variable from 2.0 to 2.8GHz using push-push oscillators. The dual-emitter transistors are biased for switching between the two signals.
Here is a different view - with dimensions on the packages, along with some surrounding components labeled. Measurements were taken via Olympus PRECiV software & an SZX-12.
