I bought this motor from StepperOnline. It's a NEMA 34 stepper motor 6.0 A 4.5 Nm.
I wired it like this (not to scale):
But I am using a variable power supply.
I have the power supply set to 30 V and 6 A, but the motor can only lift about 5 pounds. I noticed that it never uses more than 1.2 A. I tried playing around with different speeds and switch settings.
Here is current switch configuration:
Why can this large stepper motor only lift 5 pounds? I was expecting it to lift way more. Also, why is it only using a max of 1.2 A instead of the rated 6 A?
Edit:
Here is my setup. I had some rope at the end of the 3D printed part, which was holding some weight. The rope was 9cm away from the motor shaft.
Edit 2:
Here is the Arduino code:
#define driverPUL1 2 // PUL pin 1
#define driverDIR1 3 // Dir pin 1
#define enablePIN1 4 // enable pin 1
#define potPin A0
void setup() {
pinMode(driverPUL1, OUTPUT);
pinMode(driverDIR1, OUTPUT);
pinMode(enablePIN1, OUTPUT);
Serial.begin(9600);
Serial.println("setup");
void loop() {
digitalWrite (driverDIR1, HIGH);
digitalWrite (enablePIN1, HIGH);
int value = map(analogRead(potPin), 0, 1023, 255, 0);
Serial.println(value);
if (value != 255) {
digitalWrite(driverPUL1, HIGH);
delayMicroseconds(value);
digitalWrite(driverPUL1, LOW);
Here's a picture of the power supply while I'm holding the motor still with my hand (applying only about 5 pounds), you can see that it's only using 1 A.
My power supply is set to 6.4 A:
