I want to use an ADS1219 to read a voltage and send the data to an Arduino board. Instead of using the IC alone, I am using the evaluation board BOOSTXL-ADS1219 so I can test the ADC easier. After reading both datasheet/manual several times, I still have some doubts:
This ADC requires two independent power supplies: one for the analog part and another for the digital part. The thing is that ADS1219 datasheet specifies that voltage can go up to 7V, however from the datasheet diagram of the BOOSTXL-ADS1219 I understand that I need 3.3V for the digital part and 5V for the analog part. Is this ok? My guess is that this 3.3V is a must due to the dedicated port to connect to the PC. Anyways I will not use this port.
I also don't get how to connect both power supplies to the BOOSTXL-ADS1219, because this evaluation board has printed voltage values (3.3V and 5V) and not AVDD/AGND and DVDD/DGND. Can anyone tell me how to connect the four cables?. I find weird that in one side of the board I have a 3.3V pin next o a 5V pin and one ground, and at the other side of the board there is only a ground. Which ground is the analog and wich the digital?.
- Finally, I am not sure if I need a logic level converter or not for the I2C communication. Arduino uses 5V for I2C, however reading the datasheet diagram of the BOOSTXL-ADS1219 it looks like the DVDD is 3.3V, so I would need a logic level converter to go up to the Arduino 5V I2C. Is this correct?. Anyways, I have purchased one just in case I need it.
