I would like to use capacitors salvaged from old electronics, but I currently don't have an LC meter.
What would be some really simple circuits, that would convert capacitance to something I can measure (voltage, current, frequency)?
    \$\begingroup\$ Not wishing to go into the fundamental ways of how capacitance is defined, to measure capacitance (or inductance for that matter) you need a reference component to compare it against. The reference component can be a resistor, an inductor or another capacitor and if you have one that can be relied upon for its value then that is a starting point \$\endgroup\$
    Apr 8, 2013 at 17:41
    \$\begingroup\$ What test equipment do you have available? \$\endgroup\$
    – Matt Young
    Apr 8, 2013 at 17:45
  • \$\begingroup\$ I only have a cheap multimeter and xprotolab scope (scope, voltmeter, frequency counter) \$\endgroup\$
    – nana
    Apr 8, 2013 at 17:51
14
There is a solution using a microcontroller. Microchip wrote AN611 on it, but I'd recommend you this blogpost instead.
How it's done: you start charging the capacitor and time how long it takes to get to \$\frac{1}{2}\cdot V_{in}\$.
The 16F628A isn't necessary at all, you can use any microcontroller with a comparator.
With that time (the time it takes to get to \$\frac{1}{2}\cdot V_{in}\$), you can calculate the RC value of the RC circuit. You know R, it's 22K in the circuit above, it's constant. So you can calculate the value of C.
Another answer, given that you have a frequency counter, would be to build an oscillator using the 555 timer, and measure the frequency. Switch in a few standard resistors (1k, 10k, 100k etc) and check with a known capacitor how close the "frequency calculation" formula is to reality.
