As it is well known Butterworth and Chebyshev filters have explicit ways of calculating the order, derived by its polynomials.
For instance, for Butterworth filters:
$$ n \geq \displaystyle \frac{\log\left[\varepsilon^{-2}\left(10^{0.1A_S}-1\right)\right]}{ 2 \log \Omega_S} $$
and for Chebyshev filters
$$ n \geq \displaystyle \frac{\cosh^{-1}\left[\varepsilon^{-2}\left(10^{0.1A_S}-1\right)\right]}{\cosh^{-1} \Omega_S}$$
where, for both cases, \$ \varepsilon= \sqrt{10^{0.1A_P}-1} \$. To briefly explain the nomenclature used here: \$ A_P \$ is the passband ripple, \$ A_S \$ is the stopband attenuation and \$\Omega_S\$ is the normalized stopband frequency (the filters are normalized to a passband frequency of 1).
I was wondering if a similar approach can be taken for Bessel filters. My attempt was to consider the attenuation characteristic of the filters as:
$$A(\Omega)=10 \log \left[ \varepsilon^2C_n^2(\Omega) \right]$$
where \$C_n\$ is the \$n\$th order Bessel polynomial. I have taken a look at the Wikipedia for the Bessel polynomials, but they seem to have a complicated explicit formula, instead of a logarithm or hyperbolic cosine. Any idea on how can I predict the necessary order for a Bessel filter?
I think that for Bessel filters a slightly different approach is necessary.
Why does one decide to use the Bessel approximation? Answer: Because the timely properties (delay) play an important role and not only the frequency properties (3dB cut-off frequency wc). Therefore, another "frequency limit" wo is defined by the basic group delay at very low frequencies tau(w=0)=tau_o:
wo=1/tau_o.
Example: For the 2nd order Bessel low pass we have wo=wpQp=wp/SQRT(3).
Thus it can be shown that for w=wc the group delay is then tau(w=wc)=0.923 * tau_o (with 7.7% deviation from tau_o). For the 2nd order Bessel function the relation wc/wo=1.3616 is also valid.
For higher filter orders (n>2) an approximation can be given:
wc * tau_o=wc/wo~SQRT[ln2 * (2n-1)]
The maximum error is less than 5% and decreases with increasing degree n. This can be used to estimate the minimum required filter order:
n_min=(1/2)+(wc/wo)²/(2 * ln2).
The value for the basic group delay tau_o=1/wo must then be determined from the permissible deviation (in %) between tau_o and the actual delay at the frequency limit w=wc (tables available).
