Looking into the circuits and logic behind USB PD (in particular USB-C PD), I wonder why it is not more often done to combine a wall-plug PSU and a power-bank (battery powered PSU) into one. Would that not save a lot of space and cost? I seems to me that a topology of:
90-250VAC -> DC -> Buck-converter controlled by battery charge controller -> Battery -> Buck converter controlled by USB PD logic + capacitors
would be cheaper and smaller than
90-250VAC -> DC + capacitors -> Buck-converter controlled by USB PD logic + capacitors
+ Buck-converter controlled by battery charger with USB PD logic unit -> Battery -> Buck converter controlled by USB PD logic + capacitors
and maybe even more efficient in a scenario where it is not mostly used stationary? (It could even skip the battery if it is wall-powered and fully charged)
Is there any major (electrical design) reason speaking against that? Why don't we see more of these combined devices?
(Side-thought: would it not also make integration of e.g. MPPTs for solar, car chargers, etc easier? I guess that's not a driving factor for most consumers though...)
Addition: As pointed out in the further discussion, I'm talking about rather small power-banks and PSUs here. Let's say a 30-65W PSU and 30~60Wh power-bank. Also the main advantage would of course be for multi-day traveling, not so much commuting and certainly not office/home use.
