6
I don't see what it is. I think it is a 56 Ω resistor. Is that correct?
resistor
    \$\begingroup\$ Welcome! Unsolder and measure it? \$\endgroup\$
    – winny
    Jan 9, 2023 at 9:01
    \$\begingroup\$ I do it, but it is dead \$\endgroup\$ Jan 9, 2023 at 9:50
    \$\begingroup\$ Bummer. 56 ohm would be my guess too. \$\endgroup\$
    – winny
    Jan 9, 2023 at 10:48
    \$\begingroup\$ Yes, correct. From the position (looks like a series gate resistor) probably a few more bad parts are on your board \$\endgroup\$ Jan 9, 2023 at 11:17
  • \$\begingroup\$ I have replaced the resistor 56ohm and the K3067, but the power block is still dead... \$\endgroup\$ Jan 30, 2023 at 11:43
Yes, it appears to be a 56 Ω resistor.
