I want to transform a type III analog PID into a discrete-time one so I can implement it on a PIC18F. The controller is for a buck converter.
When I apply the bilinear transformation to the analog transfer function
\$ s =\dfrac{2}{T}\cdot \dfrac{z-1}{z+1}\$
how much should T be when my switching frequency is 500 kHz and loop bandwidth is 60 kHz?
    \$\begingroup\$ I'm not sure about a type III PID controller? I wasn't convinced that the internet was definitive about what "type III" means. Can you provide detail of the circuit you are trying to make digital. Include the switching regulator part please. \$\endgroup\$ – Andy aka Apr 9 '13 at 11:02
  • \$\begingroup\$ As pointed out in the answer below by CAGT: T is time between successive calculations in your filter loop. If all you are after is T then this answer is correct. If you want more details on designing your loop we need more information about the analogue controller you are trying to make digital. \$\endgroup\$ – Warren Hill Feb 3 '14 at 11:55
  • \$\begingroup\$ Are you sure about that loop bandwidth of 60kHz? That would mean your PID loop must run with at least 120kHz! \$\endgroup\$ – EvertW Apr 25 '14 at 11:57
  • \$\begingroup\$ Can you add some code and show how your schematics look? Probably many people are interested in microcontroller doing PID regulation. \$\endgroup\$ – Kamil Apr 26 '14 at 22:47
  • \$\begingroup\$ Here is a link that should help! biricha.com/converter/type/4 \$\endgroup\$ – user74867 May 5 '15 at 16:08
I think that the Type III Compensator you refer, is the one with 3 poles and 2 zeros (3p2z) used to stabilize a voltage mode buck converter. You do not describe the relationship between the loop execution frequency and switching freq. ("1 by 1" or "1 out of n"). I believe that Fbw = 60 kHz is very high to be handled with a PIC-18F - it would be more consistent with a DSP or DSC.
In order to be conservative:
  1. To avoid aliasing Fs > 2 Fbw. In practice: Sampling frequency should be 10 to 30 times the bandwidth freq.
  2. Another equivalent choice: T < 0.1 Tr, where Tr is the rise time of the open-loop system.
  3. The phase shift (degrees) in a given freq. F is -360FT. Since the ZOH (Zero Order Holder) contributes with a T/2 delay, the shift is -180F/Fs. Resulting in -180 deg. when F = Fs. So, for a stable design, pick a low T.
  4. In other hand, a very high Fs can lead to precision errors in a fixed point implementation: Remember that, with a very small T, the poles in z domain tend to unity, since $$z = e^{Ts}$$ resulting in very similar values, such as 0.999 and 0.99.
