Bear with me on this one. I have a one port circuit whose impedance has been measured from input port 'x' (the circuit is a wide complicated electrical circuit run in LTspice)
One-port network with a single impedance, Z
I was able to make it a two port circuit and extract the nodal admittance matrix of the form using LTspice (excite one port while short circuit the other and vice-versa ok?)
$$Y = \begin{bmatrix} Y_{11} & Y_{12} \\ Y_{21} & Y_{22}\end{bmatrix}$$
Now we all know that I can deduce the equivalent circuit of the now two port circuit (input nodes named 'x' and 'y') to look like this
Two-port pi network with impedances Z1 (left), Z2 (middle), and Z3 (right)
where
$$Z_1 = \frac 1 {Y_{11}+Y_{12}}$$
$$Z_2 = -Y_{12} = -Y_{21}$$
$$Z_3 = \frac 1 {Y_{21}+Y_{22}}$$
The two ports circuit's impedance equals: Z = 1/(1/(Z2+Z3)+1/Z1) which eventually is the same as the one seen in the first figure.
However when I compare the two impedances (of the first figure) and the one recomputed using the previous expression I have a problem in the phase (I have a -1 that I don't know where it's coming from?) as seen below:
This has taken a me while so feedback will be very much appreciated.
    \$\begingroup\$ The units of your formula for Z2 look wrong. You have impedance = negative admittance. Are you sure that's right? \$\endgroup\$
    – Adam Haun
    Jan 12, 2023 at 19:54
  • \$\begingroup\$ @AdamHaun Yes it is, check this paper ieeexplore.ieee.org/abstract/document/… \$\endgroup\$
    – Wallflower
    Jan 12, 2023 at 20:04
  • \$\begingroup\$ The paper is not free and costs $33 USD. I made a snarky comment earlier but I guess the point went over the moderator's head. \$\endgroup\$
    – Ste Kulov
    Jan 12, 2023 at 23:01
  • \$\begingroup\$ @SteKulov I found your comment unnecessary. There are other ways to find the paper. \$\endgroup\$
    – Wallflower
    Jan 13, 2023 at 8:44
  • \$\begingroup\$ Oh, OK. Thanks! \$\endgroup\$
    – Ste Kulov
    Jan 13, 2023 at 13:16
I can't access the paper you linked to, but according to Wikipedia and other sources, there's an error in your formula. The pi equivalent circuit for your admittance parameters is:
Pi network of admittances
The equivalent impedances should be the inverse of the admittances, but your \$Z_2\$ formula is \$Z_2 = -Y_{12}\$, which is still an admittance. Try using:
$$Z_2 = \frac 1 {-Y_{12}}$$
  • \$\begingroup\$ Yes you are right about that, I made a mistake writing the question, but my script is still correct \$\endgroup\$
    – Wallflower
    Jan 14, 2023 at 14:39
