Today, I came on a PC board and the silkscreen marking have TG on it. What is the component for TG? enter image description here
    \$\begingroup\$ Do you have a photo? That's not a very common one. Are you sure it's a designator and not the PCB material spec? \$\endgroup\$ Commented Jan 12, 2023 at 21:24
  • \$\begingroup\$ Is the TG marking followed by a number? Possibly a European designation for a Gas Discharge Tube (GT vs. TG). If used alone it might even designate that the PCB is made of a high temperature material, (The TG specification for a PCB is related to the "glass transition temperature" of the actual PCB material.) \$\endgroup\$
    – Nedd
    Commented Jan 14, 2023 at 11:35
  • \$\begingroup\$ More insight here: electronics.stackexchange.com/questions/718772/… \$\endgroup\$ Commented Jul 8 at 19:54
No one checks designators, there's no like universal regulatory process or anything -- at most, in-house standards apply, or only what is dictated by contract terms. There are standards, such as ANSI-Y32.2 (1975), but "TG" is not among them.
So, it could mean anything.
The component in question appears to be a multilayer or ceramic component: ferrite bead, thermistor, MOV, etc.. Ferrite bead wouldn't make much sense in parallel with a relatively large resistor, and MOV maybe. A thermistor, for sensing ambient temperature on the board, beside perhaps a comparator to set a threshold, is a definite possibility.
We can't know for sure without tracing the surrounding circuit, knowing what the other components are, connectors, etc.
